Safety
167
Posted
Introduction: Safety
Welcome!
Your safety and the safety of other are very important. Please take time to carefully read the safety messages contained in this manual.
The following topics will be covered
  • Safety Messages and Safety Alert Symbols
  • Hazards
    • Resin
    • Isopropyl Alcohol
    • Sharp tools
  • Radio and Television Interference
  • Restricted Substances
Step 1: Safety Messages and Safety Alert Symbols
This is the safety alert symbol. This symbol alerts you to potential hazards that can kill or hurt you or others.
All safety messages will follow the safety alert symbol and the word "DANGER","WARNING" or "CAUTION." These words mean;
DANGERYou can be killed or seriously injured if you don't immediately follow instructions.
WARNINGYou can be killed or seriously injured if you don't follow instructions.
CAUTIONYou can be moderately injured or damage your equipment if you don't follow instructions.
All safety messages will tell you what the potential hazard is, tell you how to reduce the chance of injury, and tell you what can happen if instructions are not followed.
IMPORTANT SAFETY INSTRUCTIONS
  • Disconnect power before servicing
  • Replace all parts and panels before operating
  • Plug into grounded 3 prong outlet
  • Do not remove ground prong
  • Do not use an adaptor
  • Do not use an extension cord
SAVE THESE INSTRUCTIONS
Step 2: Hazards
RESIN
WARNING
Toxicity Hazard
Do Not use parts produced from this machine for storing, serving or touching food and drink
Failure to do so can result in poisoning or other injury
WARNING
Serious Eye Irritant
Avoid contact with eyes and wear eye protection/face protection
Failure to do so can result eye injury
WARNING
Skin Irritant
Avoid contact with skin and clothing and wear protective gloves/protective clothing
Failure to do so can result in skin irritation
When handling Autodesk resin you should follow standard chemical handling procedures along with the resin specific information contained in the Material Safety Data Sheets (MSDS).
Resin Handling Procedure
  • Do not handle until all safety precautions in the MSDS have been read and understood
  • Avoid contact with eyes, skin and clothing
  • Keep container closed when not in use.
  • Wear protective gloves/protective clothing/eye protection/face protection
  • Wash face, hands and any exposed skin thoroughly after handling
ISOPROPYL ALCOHOL
DANGER
Highly flammable liquid and vapour
Keep away from heat/sparks/open flames/hot surfaces
Failure to do so could result in ignition or explosion of Isopropyl Alcohol
Autodesk does not manufacture or supply IPA. You should consult the manufacture’s Material Safety Data Sheet (MSDS) for detailed safety information
IPA Handling Procedure
  • Avoid breathing vapours
SHARP TOOLS
WARNING
Laceration Hazard
Always follow the instructions when removing parts from the build head, keeping fingers and hands out of the direct line of motion of the scraper
Failure to do so can result in minor injury to hands, fingers or other
The Finishing Kit contains sharp tools, please take care when using them and follow all instructions.
Step 3: Radio and Television Interference
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: 1. This device may not cause harmful interference, and 2. this device must accept any interference received, including interference that may cause undesired operation.
Step 4: Restricted Substances
WARNING: This product contains chemical(s) known to the State of California to cause cancer and birth defects or other reproductive harm.
WARNING: For distribution in Europe, this product may contain substance(s) of high concern including: (list of substances).
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
