Whippings are preferable to back-splices whenever there is a need for the rope's end to pass through an eye or a block. I think a whipping is always preferable because a back-splice will catch on anything at the most inconvenient moment.
Whippings are usually made from waxed twine or rope yarn. For my example I've used some braided cord. A boot lace will do.
The length of a whipping should be at least equal to the diameter of the rope, and for permanent whippings, a second one should be made nine diameters from the end.
My favourite whipping is the sailmaker's whipping. I think it looks great and I've never seen one work adrift. Here's how to make one...
Remove these ads by
Signing UpStep 1: Getting Started
- Get the end of the rope to be whipped in one hand.
- Get the twine in your other hand.
- Poke the end of the twine through the rope passing under one of the strands. About 200mm from the end of the rope.
- Now pass the twine over the next rope strand and then through the rope again going under the last strand. It should come out between the same two strands you first poked it through.
- Pull the twine through to give yourself about 200mm hanging out.
- Leave about 50mm of bight hanging at the back.
- You should now be ready to start whipping.
Visit Our Store »
Go Pro Today »
http://en.wikipedia.org/wiki/Constrictor_knot
The only draw-back with this knot is that, once pulled down tight, you'll have to cut it to get it undone. When whipping a rope, I pull it tight with a couple of pairs of pliers, with jerking action to pull it up REALLY tight. You can then cut the ends off very close, it won't come undone.
Yes, I think this is the best permanent whipping for any natural fibre rope.
When I was working on barges I would whip the ends of all the larger ropes and then lightly melt the tips. The result was very professional looking. And the whipping would generally outlast the rope.
