Sainsmart LCD Shield
24,797
29
12
Posted
Introduction: Sainsmart LCD Shield
This instructable will show you how to use a SainSmart LCD keypad shield.
You will need:
- An Arduino Uno
- SainSmart Keypad shield
Get one here: Here
- USB cable
Step 1: Setting Up
Place the Shield onto the Uno, and plug it in.
Step 2: The Code
Make sure you have the LiquidCrystal library installed.
// LiquidCrystal Print
// by Parzivail
#include
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
void setup()
lcd.clear();
lcd.begin(16, 2);
void loop()
lcd.setCursor(0, 0);
lcd.print("Hello, World!");
Step 3: Done!
Congrats, you have a working LCD shield.
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
For me to get the above code to work I had to change this to this
#include
#include
8 Comments
Not sure if you're still looking for button control on this, Bob, but the link below will give you pretty much everything you need. You'll probably have to tweak the values of readkey a little bit, but it worked just fine for me once I figured out the right values there.
(mine, incidentally, were left, 504; right, 0; up, 143; down, 328; select, 741; and null (no key pressed) was 1023. I haven't checked the other board that I got yet to see if it's the same values, but I suspect that each board will be slightly different based on tolerances in the values of the resistors used.)
https://codegists.com/code/arduino-lcd-keypad-shie...
Found the button control thanks.
Turns out I use similar routines quite a lot on other projects now after looking at the schem. sometimes simple as they use can have lots more uses.
No sketch works for me...
My shield just shows blocks in the first row, in the second nothing.
I`ve adjusted the gama also, any other recomandations?
it works ;)
I had to push it really deep in
Thanks I had troubles right away. This is the EXACT code that worked for me.
#include <LiquidCrystal.h>
// by Parzivail
void setup()
lcd.clear();
lcd.begin(16, 2);
void loop()
lcd.print("<3 You Angela");
Kyle, the code looks like it worked, but the screen doesn't show any words, just blocks. Any recommendations? Thanks
Try adjusting your gamma with the little potentiometer thing
