3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Salmon Tartare Coronets
A spiffy appetizer from the French Laundry cookbook, with details.
Step 1Prepare coronet forms
To properly roll the cookies into their ice cream cone shapes, you'll need a conic form that can withstand some time in a 400F oven.
The cookbook suggests a #35 4 1/2" coronet mold, but since this was a one-off for a French Laundry themed party we decided to make our own out of paper.
After some rummaging, I found a 4" diameter circular object for tracing (the base of a pitcher) and made some circles on a manila folder. I also made one on a sheet of glossy paper, the thick stock used as the cover of an expensive yuppie magazine we magically get for free. Note that I'm NOT putting the glossy stuff into the oven for fear of toxic bleeding or outgassing; that's what the manila folder is for.
Draw another circle on the glossy paper ~1/2" outside the original circle, and add a tab. Now cut around the outside circle and inside of the 4" circle to make a 4" diameter stencil.
Cut out the manila circles; I used 5. These need to be shaped into cones for use as your forms, so you've got to get them nice and tight. I wanted to staple them into position, but they're too small to successfully staple. We also nixed glue, tape, and rubber bands as unable to stand up to oven conditions. Pinning sounded good in theory, but probably would have ended in tears. I finally ended up sewing them in place, which was surprisingly fast. The key is to pass the thread directly THROUGH the cone, then wrap around the flap as you prepare for your next pass. After three or so stabs across the cone, exit next to the original knot (you should have made a BIG knot, and left an inch or so of tail) and tie off with the tail. These worked beautifully, and looked sort of spooky.
10 comments
Nov 26, 2007. 4:44 PMStasia says:
I think I need to come to your house and just eat everything in your fridge. Yum. Stasia
Nov 25, 2007. 11:24 AMastrozombies138 says:
i believe people often use uncooked eggs as a sort of "glue"
Nov 26, 2007. 9:13 AMjongscx says:
that's how we keep eggrolls closed. After we wrap the wrapper around the meats, we smear some beaten egg onto the loose flap (kinda like licking the wrapper when you're rolling a cigarette) I think it prolly has something to do with the proteins binding when the water evaporates, or when it gets cooked...
Nov 25, 2007. 7:53 PMjongscx says:
This uses Raw Salmon, right? Isn't there some danger with pregnant women and large sea-faring fish? Mercury or something... not sure. I actually work at an ice-cream shop, and we have little plastic cone-forms. I asked my boss, they were only about $15 each, so it may be worth it to buy them if that's what you're looking for. I guess they won't work if you need to bake them again after shaping them. What about those little bottles that alcohol comes in in airplanes (or used to) Could you use those? Chance of breaking though, so probably not.
Nov 25, 2007. 3:58 PMtexabyte says:
my dad and i both love salmon. i'll have 2 try it sometime!!!!!!!!!
Aug 9, 2007. 4:16 AMjewdrew says:
Yumm! Thanks for the wicked recipe. Makes me super hungry too. :)
Jul 31, 2006. 7:07 PMfungus amungus says:
Holy crap! You don't fuck around. Now I'm hungry.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
414
Author:canida
I've been posting Instructables since the site's inception, and now run Community and Marketing. Follow me for food and more!
