In this instructable I will tell you from personal experience how to suprise your victim(s) with a live salmon in a canoe.
There are a few basic things you will need to accomplish this prank:
1. Canoe
2. Fish
3. Bucket
4. Opportunity
You may also need
5. A screwdriver to remove doors or windows to get the canoe inside
6. Small pieces of wood to prop up the canoe to keep it upright
7. Tape-measure to ensure your vessel will fit
8. Friends to make it much easier and faster
Remove these ads by
Signing UpStep 1Determining The Perfect Location
Making sure the canoe will fit in the room is key depending on the amount of furniture and exact length of the boat. You must also check to see if there are any tight corners or hallways that might not be maneuverable. In this case, you will have to resort to a window checking to see if there is one big enough and will open far enough.
![[Collegiate Meals] Three Way Salmon Steaks](http://img.instructables.com/files/deriv/FMN/UW69/1WBEY95VDNI/FMNUW691WBEY95VDNI.SQUARE.jpg)
wish I could pull that on my wife!!! that was great!!!
If you do this with a freshwater fish and water from the tap, make sure to buy dechlorinator from the fish section of walmart or petco. If you dont the chlorine in the tap water will burn the gills and eventually kill the fish you put in the canoe.
