Salt Water Leyden Jar
6,071
83
11
Posted
Introduction: Salt Water Leyden Jar
So this is a fancy shmancy Leyden Jar. It's basically a jar filled with salt water with aluminum foil around the outside of the jar. In essence, this is a capacitor, so when you charge the inside (negative) the grounded outside would then become charged as well with the opposite charge of equal value (positive in this case). When you then touch the wire thingy to the nail on top you would be neutralizing the two sides causing a spark between the wire and the nail.
Step 1: Step 1: Get Your Materials.
You're going to need a glass jar, four pieces of tape, much salt, an a wire.
You also need a jar lid that fits the jar you have with a nail nailed through it. We would have showed a step for this but by the time we started making this Instructable we had already had a jar lid with a nail nailed through it, so we're sorry we're lazy but we don't want to do that again just for the sake of pictures. Also note that we hot glued the nail into the hole too because we didn't want to be electrocuted.
Step 2: Step 2: Fill Your Jar With Water Around 3/4ths Full.
Find a sink and fill your jar.
Step 3: Step 3: Add Salt
Add copious amounts of salt to your water. Like a lot of salt, but not enough to have more salt than water. just enough for the water to be kind of cloudy.
Step 4: Step 4: Screw on the Lid
so nothing spills, also try to make sure that your nail can reach the salt water.
Step 5: Step 5: Wrap a Piece of Aluminum Foil
wrap and tape the aluminum foil around the jar.
Step 6: Step 6: Tape the Wire
Tape the wire on the aluminum foil somewhere kind of like the picture. make sure the tip of the wire can touch the nail and the other end can touch the aluminum.
Step 7: Step 7: Test It
So you should charge the inside part of the Leyden Jar somehow. Our method was rubbing wool on a plastic rod and then rubbing the charged rod onto the nail. But thats just us. Our own results were a little iffy, we managed to get it to spark a couple times, but not entirely consistently, We'd suggest trying to get it to spark in a dark room so that you can see the spark when it happens.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
11 Comments
TO MUCH POWER
It's all science. Some ions must have been released and charged the capacitor. Be Careful!!!!!! No one needs to die.
ditto on boatingman's comment. these simple capacitors can easily kill you. I was knocked unconscious when a homemade capacitor was left sitting near an ionizer air cleaner. at some point during the day, someone had turned on the air cleaner briefly, which, unbeknownst to me, had left me a fully charged capacitor. all i remember is reaching for it and feeling like I'd been kicked in the chest by Chuck Norris, lol, so do be careful.
Wow. Please be careful. This type of capacitor is extremely dangerous and can easily be lethal. Fun, but deadly.
Cool Leyden Jar project!
I've never heard of a Leydon jar before. Very cool!
A Dutch scientist who lived in Leyden (a town in Holland) at around mid/end 1700. He invented it.
It's probably worth mentioning the screw-on top should be non-conducting.
I made one of those and hooked it to a 50kV power supply with a spark gap, that was very loud and terrifying.
To further insulate it you can pour some oil, which will float to the top insulating the salty water from the exterior.
