Salt Water and Aluminum Foil Night Light
A simple classroom (no soldering) project  to show aluminum air batteries in use. In this instructable I will show you how to create a simple 3 cell aluminum air fuel cell using household aluminum foil and saltwater. You can use this to drive a small light or possibly a motor. This device will function for extended periods as long as the fuell cell is periodically recharged with electrolyte and the aluminum foil is replaced when power output drops below acceptable levels.
To simplify construction I used one of those solar yard lights available from OSH, Home Depot or Lowe's for about $5. These contain a simple circuit to recharge a battery along with a Joule thief type circuit and use that to drive a super bright LED after dark. Sundown is detected by a photocell located on the face of the device.
This circuit has many drawbacks but it eliminates the need to build a circuit or run down to Radio Shack, although obviously for a science fair project one would presumably build a simple joule thief/recharger circuit.
The design can be scaled up with additional cells wired in series or in parallel to increase power output and the output power can be fed to any suitable low voltage circuit. Do a web search for "solar powered light circuit" and substitute the appropriate al/air fuel cell array  for the solar panel(s).
Now let's take a look at what we're going to need for this project.
Step 1Bill of Materials
Bill of Materials
The basic construction of this device is extremely simple. We're going to use some non-conductive trays and make a sandwich of aluminum foil, paper towels and a carbon brush electrode which begins its life as an aquarium filter.
You're going to need some non-conductive tray containers. I used some carryout containers from a local rib joint but almost any tray may be used. Since there only two dinners I used two bases and one lid. The common glass 9X11 glass cooking trays would be perfect.
3 paper towels to act as the porous layer.
A box of carbon aquarium filters. I used the Fluval brand of carbon pad replacement filters available at PetSmart for about $4. These come 4 to a box, I used the "4 Plus" size. These are used as the carbon electrodes in our assembly and function in this role quite nicely.
Some salt to use as an electrolyte. Ordinary table salt is fine, you'll need about 5g to start with. That's approximately 1/2 TBSP. In a liter of water that should produce approximately a 5% solution. Feel free to vary electrolyte strength.
A solar yard light. (see picture). These are available at most hardware stores for about $4. This is a self contained solar powered light with a rechargeable battery. it works by using a joule thief type circuit to maximize energy stored in the battery, the difference being that this circuit uses a capacitor rather than a traditional toroid so it doesn't provide the power amplification normally associated with a joule thief. NOTE: In the joule thief circuit the toroid provides both power amplification and capacitance.
4 electrical leads with clips, these are available from Radio Shack in a package of 12. These are used to make all connections.
A scissors, ruler and ball point pen along with a small screwdriver for dissassembling the solar light.
Now let's get started...
45 comments
1-40 of 45next »
Jan 7, 2010. 1:19 PMkclo42112 says:
nice experiment a simple galvonic cell , I used to use a lemon to get the same effect,any acid or in this case a ionic solution,and to disimilar metals will create electricity, but this one can be done at any diner table with scraps,basicly
Jan 9, 2010. 9:27 AMkclo42112 says:
Now you got me thinking about that old electronics kit from radio shack I had waayyy back when.... I think theres some graphite rods from some old dry cell batteries in that box,I could teach this trick while camping with my nephews
Jul 18, 2011. 5:22 PMserp1000 says:
brilliant instructable :) im going to go and try that now. Im studying engineering and technology and think fuel cells are extremely interesting and could become the future, expecially hydroged based or methanol based fuel cells.
By the way, if you've got a camp fire you dont really need the light do you... :D
but i still think its a great idea and would do the very same thing on a camping trip :)
May 8, 2011. 8:44 PMJORDANBOOKE says:
what is another option for a carbon electrode. i cannot find the fluval carbon pads anywhere. were your carbon pads filled with small carbon "rocks"?
Jun 12, 2011. 10:43 PMThnder says:
As I understand it, you just need two different metals to cause the galvanic reaction. Copper can fill this requirement so you could try copper flashing. You might be able to find this at your local Hardware store.
Jun 21, 2011. 9:03 AMThnder says:
I am no expert, what makes it non-reactive?
Mar 9, 2010. 3:06 PMBlankBome7 says:
so what did you do with the salt to make this work and did you put layers of alumine foil down or one
Nov 3, 2010. 5:05 AMUdon says:
More aluminium? Do you mean adding more SEPERATE layers of foil, or more sheets of foil at the same electrode? For more surface area?
May 7, 2010. 11:20 PMsmeezekitty says:
One correction: It isn't 'air' but rather a saltwater reaction.
Also zinc may work better then aluminum.
Mar 12, 2010. 10:55 AMBlankBome7 says:
agian sir if you dont mind me asking im srry im new i dont know mutch but is that yellow wire a positve or negative please do tell my teacher is useing this site and this is my project i have chosen and the teacher is really anoying
Jan 2, 2010. 3:44 AMnecropolian says:
Wonderful project, although I do not really understand it. does it recharge itself, or is it simply a fuel cell?
anyway, 4.5 for the rating.
Jan 3, 2010. 5:33 PMfranklinonline says:
 so it acts like a not very effecient battery right? It charges the other one inside the light, then after a while it dies.
Jan 14, 2010. 4:19 PMfranklinonline says:
 If you somehow used thicker aluminum sheets, would it last longer. Or is it the carbon that is used up. And how would this be different than a battery? Is it that batteries dont need fillups on electrolyte?
Jan 21, 2010. 1:19 PMlucek says:
no sir this is a battery. your definition of a fuel cell is a little off.
"Fuel cells are different from conventional electrochemical cell batteries in that they consume reactant from an external source, which must be replenished"
http://en.wikipedia.org/wiki/Fuel_cell
in this cell it remains a closed system replacing the anode isn't the same as having an external supply of fuel.
Jan 21, 2010. 5:49 PMlucek says:
by the way that was a failed argument from authority. you didn't show that "Lawrence Livermore National Labs" appears to agree with you let alone that the description was accurate.
Jan 22, 2010. 11:00 AMlucek says:
from your own quote "between the fuel (on the anode side) and an oxidant (on the cathode side).The reactants flow into the cell, and the reaction products flow out of it, while the electrolyte remains within it. Fuel cells can operate virtually continuously as long as the necessary flows are maintained." the device you have here meets none of thees 3  criteria. there is no oxidant on the cathode side there are no reactants flowing into the cell and the products remain in the cell, nor is there a flow to be maintained.
as for your question if I have something useful to do. this is my break. and despite your Monty Python clip I'm not here for an argument. I read your instructable and comment, left some of my own and then was going to leave.
Jan 21, 2010. 5:44 PMlucek says:
by your definition the fuel cell was invented in 1800. the fact is that a fuel cell has a separate fluid that supplies energy and the anode and cathode do not. what you are describing is know as a battery.
Jan 21, 2010. 1:08 PMlucek says:
we used to do this back in school with aluminum foil paper towels and pennies. pretty simple homemade battery. but what we'de do is make a stack penny foil paper penny etc. then put that in a empty film container. use a paperclip as the terminals. it was like a real battery.
Jan 17, 2010. 8:31 AMbuteman says:
Like this, great idea. Could I just ask did you mean 0.5% solution which 5gm in 1L is or 5%  i.e 5gm in 100mls?
Jan 7, 2010. 8:26 AMHerber says:
Nice article.  I think that if you put 5gm salt in 1L water in step five you have a .5% solution? 5gm in 100ml would be 5%?
Jan 7, 2010. 10:59 AMToniRose says:
If you're not a science teacher you should be. What I like best about this ible is that it demonstrates a couple of simple concepts but can be revisited to add knowledge (ie, the toroid for amplification). Excellent!
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
144
Author:egbertfitzwilly(More about me at LinkedIn....)
