3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Salvage 9V battery clips from dead batteries
You can use the top of an old 9V battery as a 9V battery clip for assorted
electronics projects. The "9V clip" is also used on some batter holders of
assorted voltages (ie a 4AA battery pack.)
Here's how to make a nice wire-lead version...
(This is an old idea. The only original part here is the "strain-relief" hack.
Still, new pictorials for old ideas can be pretty useful.)
Step 1Find a dead battery...
Find a dead 9V battery. Batteries are supposed to be recycled these days,
so a good place to find dead one is at work, where they might have battery
recylcling stations.
The internal construction of 9V batteries varies a great deal, and some are
easier to convert to clips that others. Duracells are pretty good.
44 comments
1-40 of 44next »
Mar 18, 2012. 2:08 PMlden hartog says:
some batteries are so poorly manufactured that they can just be pulled or shaken apart :)
Jun 26, 2006. 10:42 PMElFantastic0 says:
i've been doing this for years. use a pair of small end-cutting pliers on the top crimp and then peel the can open like a sardine tin. it takes just a few seconds and the "used" clip is usually better than most purchased ones.
Nov 2, 2011. 12:48 PMcharlieb000 says:
i fill the inside of the bought clips with hot glue (may work just as well with silicon) and this helps alot with strain releif also, just dont get burnt... but yours is better
Aug 7, 2011. 3:13 AMcurious youth says:
yeh but you saved 15 cents
Jun 21, 2008. 6:07 PMDarkStar851 says:
I already knew how to do this, but the radio shack here recently closed down, and an ugly "The Source! by Circut City!" Replaced it, their prices are insane. This is happening a lot in other parts of Canada too, so I hope this Instructable helps a lot of canadians.
May 29, 2011. 7:07 AMjosh1324 says:
oh my god me too! We used to have an awesome radioshack but now all we have is the source!
Example:
Me- Im lookin for a 500K ohm potentiometer
Store Person- ....... Huh?
Me- -_-'
Jan 21, 2010. 8:23 AMprofpat says:
super great idea!
Dec 1, 2008. 10:52 AMtaffypride says:
thinking about doing something with a PP3 (9v) battery block and making a USB emergency charger for my ipod using this: http://www.maplin.co.uk/Module.aspx?ModuleNo=36603
Saves fiddling about ripping open old PP3 (9v batteries).
Jun 29, 2008. 12:15 AMshibogee says:
omg, lol i was so sure that no1 had put this on instructables yet :'( lol
Apr 7, 2008. 4:22 PMendolith says:
Sure you can get them for $0.15, but you'll have to wait a week for delivery. It's not like you can buy them in stores anymore. This is a very useful substitute for when you don't have any lying around and need one quickly. Thanks!
May 11, 2006. 1:06 PMSilas says:
I think this is more of a lazy man's mod.. Who would take the time to get to the store to buy these things, when you can do it yourself at home? I've been doing this for years, and they work great.. I can make one in about 2 min max.
May 13, 2006. 12:05 AMCrash2108 says:
Or you can always have some children do it for 10 cents a day, thats the cheapest way.
Mar 22, 2008. 10:01 PMFull Frontal Graphic says:
Like the big companies do, smart thinking. Eventually there will be no jobs in the US at all and we can all just sit around making gadgets.
May 11, 2006. 9:46 AMspojaz says:
yeah, but 9 volt batteries are actually batteries, not just cells. That means the acid is stuck in those other things that resemble AA "batteries" (cells)
Mar 14, 2008. 7:56 PMcomputerwiz_222 says:
This does not matter. A cell is like a AA battery but smaller and has no label. The size is AAAA to be exact. Sometimes, AAAA's with tabs can be used in place of an AA or AAA. Don't try this, but this is to prove how similar they are.
May 11, 2006. 7:25 PMjaredforshey says:
The real value in this sort of project is three-fold: you get to make it yourself, you get to reuse stuff that's probably heading for the trash, and it's a great way to quickly scrounge up a battery clip when you want to try something _now_. Sure, 5 volt regulator IC's can be had cheaply and are common enough to even make a token appearance at the local Radio Shack ("You've got questions, we've got batteries!"), but how many of us have thrown together resistor networks or chopped off a USB cable to get access to a 5 volt source in a moment of heated inspiration? Remember, serious hobbyists don't hold off just because they don't have the parts on hand!
Mar 14, 2008. 7:53 PMcomputerwiz_222 says:
lmao i was doing USB electrolysis of water the other day. It worked surprisingly well. I should be careful not to overload the IC for the USB Port. I do this kind of crap all the time and I love it lol
Mar 2, 2008. 8:03 AMedfel01 says:
looks awsome
Dec 3, 2007. 3:52 PMmaker12 says:
i opend up a sunbeam 9v and got SCREWED!! :SOB
Jul 13, 2007. 12:46 PMJamesRPatrick says:
I love the fersitility of a 9v. I fou snap two together, they'll heat up and possibly explode.
Aug 13, 2007. 4:17 PMduct tape says:
I've made one explode before...
Dec 3, 2007. 3:50 PMmaker12 says:
easy conect 9v to car batt and run!
Dec 11, 2006. 4:47 PMi make shooting things says:
when i mess with batteries they tend to exsplode.
YUP!
Nov 28, 2007. 3:10 PMmaker12 says:
the kipkay 9v to aaa hack i had falled at that but this works!
Jun 5, 2007. 11:12 PMn0ukf says:
I've found that the better ones to solder to are those with a fiber (like cardboard) carrier rather than the plastic carrier. The plastic ones tend to melt and deform if you hold the iron on it too long (sometimes necessary to get it tinned).
Oct 29, 2006. 3:39 PMdfowler7437 says:
I have an article about using the PC to supply power to electronics projects at http://www.uchobby.com/index.php/2006/10/29/power-projects-from-your-pc/
I also have a parts scrounging article that might be of interest at http://www.uchobby.com/index.php/2006/09/01/scrounging-a-3com-super-stack-ii/
Jun 28, 2006. 12:34 PMGoodAtIt says:
KOol.
May 14, 2006. 5:35 PMjaredforshey says:
Another point worth mentioning is that in certain brands the cells will be flat rectangular packs instead of the cylindrical variety. Also, in the cheaper varieties, you'll find they sometimes skimp you by being one cell short of the necessary 6! With only 5 cells, they barely get away with being called 9-volt batteries because of the fact that new, freshly-charged cells often have slightly higher voltages that combined make up for the lack of a cell - but not for very long.
May 11, 2006. 4:16 PMsaltermd says:
The only thing I must say is that if you gently use a small tip slotted screwdriver, you can easily pry the lip open on the top or bottom of the battery to remove the contents. I like to take the emptied case and use it for other small projects. One is that I cut a 5mm hole in the bottom shield for a super bright LED, cut a small hole in the side for a switch, and wire in a 1000 ohm resistor to make a flashlight that plugs right into another 9V battery. It's lightweight and lasts a loooong time. Do yourselves a favor and see what else you can fit in those cases. P.S. Use your dead 9V's, not the good ones!
May 13, 2006. 11:27 PMJafafa Hots says:
If you could do this and submit it, I think that would make a hell of a fun project. I want to turn a BIC lighter into a USB thumb drive, personally.
May 12, 2006. 12:37 AMklee27x says:
I just gained newfound respect for the 9V battery. Rewire the cells for common 3, 4.5, or 6V projects, and the storage capacity is no longer a joke.
May 11, 2006. 10:39 PMHeerMatt says:
I think this is a great idea. I teach a HS electronics course and we're ALWAYS needing these things. Thanks a lot!
May 11, 2006. 7:09 PMklee27x says:
This is so cool that I just spent ten minutes looking tru my rubbage for the battery I threw away two days ago. Didn't find it, though. :)
** 9V connectore are about 50 cents at my Radioshack, 2.50 for a 5 pack. **
May 11, 2006. 7:08 AMranex says:
old batteries have the same battery acid as the rest so this might not be the best of ideas
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
