Remove these ads by
Signing UpStep 1Desoldering
First bend a piece of thick copper (or other solderable metal) wire to fit around the component, and contact all its solder pads. Solder it in place. This is done to make thermal contact.
Then heat the wire at a central place with your soldering iron, and lift the component away with tweezers. Or push it away using a wooden toothpick. Only don't be too enthusiastic with the push or it will fly across the room and be lost forever in the crud that covers the (in my case anyway) floor.
These are best stored inside foam cutouts in a suitcase. Miniature, of course.
desol.avi1 MB| « Previous Step | Download PDFView All Steps | Next Step » |
its a hot air gun for working with surface mount components.
A 564 resistor is actually 560,000 ohms(560 Kohms) and NOT "five hundred and sixty thousand Kilohms".
Thanks.
Nice instructable though... I like your method. You might also try making one of these:
http://www.engadget.com/2006/03/07/how-to-make-a-surface-mount-soldering-iron/
http://www.gideontech.com/content/articles/297/1
http://www.usbmicro.com/odn/documents/ACC430664DD26DDE5986574AAA62775FDFF29EA1.html
You could also try using a clothes iron, like in this video:
http://video.google.com/videoplay?docid=-5064927163860056532
just slce under the LED and it will slide off the board with the knife, but dont put too much pressure on the knife or else you will either hurt yourself, other components on the board, or the surface you are working on.
i used this technique and out of 14 blue leds from a cell phone board, i got 10.
the other 4 were lost among the floor that happens to match their color.
i lost a few while learning to solder them, but it was a learning experience for getting them off, and it does wirk with patience.
i usually store my smd components in a small plastic bag (like you get those perfboards in @ radioshack), but a better storage method will have to be in order since the bag has a few holes in it.
http://www.engineeringlab.com/supkiten.html
or you can do it on the cheap like me and get those small plastic coin holders for dimes....
http://www.uchobby.com/index.php/scrounging/
