3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Salvage surface mount components
I shall tell you how I rescue components from old circuit boards and store them for reuse. A board from an old (relatively new, that is) hard disk drive shall be shown for an example. The photo (taken using my scanner) shows one such board, after I removed the IDE connector.
Step 1Desoldering
Desoldering
I have a movie showing my process. I am attacking a tantalum capacitor in the video, but the same process works for all other components too.
First bend a piece of thick copper (or other solderable metal) wire to fit around the component, and contact all its solder pads. Solder it in place. This is done to make thermal contact.
Then heat the wire at a central place with your soldering iron, and lift the component away with tweezers. Or push it away using a wooden toothpick. Only don't be too enthusiastic with the push or it will fly across the room and be lost forever in the crud that covers the (in my case anyway) floor.
These are best stored inside foam cutouts in a suitcase. Miniature, of course.
47 comments
1-40 of 47next »
May 12, 2012. 11:46 AMzaphar says:
I'm interested in salvaging ICs and whatever I can for educational projects, however, which parts are worth saving. The ICs seem like a no-brainer (at least the ones that have datasheets) but what about other components? I think I read somewhere that some SMD components are not worth salvaging due to lack of information on them (no datasheets or info). Could any knowledgeable individuals chime in on this?
Dec 5, 2010. 7:57 PMJimmy Proton says:
so how do you remove those IC's with 5000 pins?
Dec 14, 2010. 6:40 PMratgod says:
You can use a paint stripping heat-gun if you don't have access to a solder reflow workstation. It worked fine for me until I got mine a few months ago :)
Dec 15, 2010. 4:33 AMJimmy Proton says:
what about a toaster oven, i have removed components off a board with one (accidentally) but it is reliable? and what it a solder reflow workstation?
Nov 4, 2011. 1:34 PMratgod says:
sorry for very delayed response,
its a hot air gun for working with surface mount components.
Aug 14, 2011. 9:45 AMTerrean says:
A correction needs to be made in your Instructable.
A 564 resistor is actually 560,000 ohms(560 Kohms) and NOT "five hundred and sixty thousand Kilohms".
Jan 30, 2007. 12:42 PMrobonut625 says:
Jul 26, 2011. 11:24 PMSinAmos says:
The Iron Is Genius!
Aug 29, 2010. 10:45 PMbeehard44 says:
thanks for the clothes iron video! i just have a crappy soldering iron and i think the clothes iron trick will do nicely!
Dec 14, 2009. 10:24 PMnullsmack says:
That clothes iron video is amazing. Thanks for sharing it.
Jun 15, 2009. 9:55 PMReCreate says:
Genius!
Jul 26, 2011. 11:22 PMSinAmos says:
I love you. Good work.
Jul 25, 2011. 1:06 AMzack247 says:
ive found a partially successful way to remove SMD leds with no chance of melting them and a small chance of breaking/losing them is not with a soldering iron, but a small exacto knife.
just slce under the LED and it will slide off the board with the knife, but dont put too much pressure on the knife or else you will either hurt yourself, other components on the board, or the surface you are working on.
i used this technique and out of 14 blue leds from a cell phone board, i got 10.
the other 4 were lost among the floor that happens to match their color.
i lost a few while learning to solder them, but it was a learning experience for getting them off, and it does wirk with patience.
i usually store my smd components in a small plastic bag (like you get those perfboards in @ radioshack), but a better storage method will have to be in order since the bag has a few holes in it.
Aug 22, 2010. 2:17 PMdevinmccloud says:
The easiest way is to lock the board on a vice. Use a heat gun at high speed on the backside. Slowly remove the components with tweezer or needle nose pliers. Store components on an aluminum surface to cool fast. 99% of the components are good and reusable. Use google to look up datsheets for IC's. Then organize components by type and size. I can strip a motherboard in 3 minutes this way.
Mar 27, 2010. 12:55 AMzack247 says:
how to do leds??? wont it melt from the heat?
Sep 4, 2007. 11:27 PMTheMadScientist says:
aha! so that is an old harddrive board!
Jul 22, 2008. 1:49 AMDerin says:
"so that is an old fujitsu harddrive board!"
Mar 27, 2010. 12:54 AMzack247 says:
ahh... i have 2 dead fujitsus, they were very good quality if you ask  me...
Aug 22, 2009. 9:43 AMtanmanknex says:
isn't the one you want always going to be the one you turn over last? why would you keep looking after that? jk ;D
Apr 11, 2009. 8:23 PMeric m says:
nicde. marx generator
nice
Apr 11, 2009. 8:22 PMeric m says:
IC's are such a waste. I wanted an led display and chip but you know the chip is impossible to figure out. just a waste. Ofcourse component makers don't want a used market undercutting them.
Jan 8, 2009. 9:20 PMaltomic says:
-big pot -cooking oil -stove -scooping net thing. put pot on stove add oil turn on stove when it it super hot throw in your pcb. stuff will melt off. IC are made to withstand hightemperatures. solder will melt before there is damage to the IC. scoop out IC with skimmer thing. party on.
Feb 1, 2009. 3:54 PMjackillac92 says:
Are there any noxious fumes from doing this? Will I still be able to get regular resistors from this or willt hey melt? Will anything bad melt? Do an instructable on this please!
Apr 6, 2009. 7:42 AMalex-sharetskiy says:
plastics might melt
Mar 18, 2009. 5:16 PMgeeklord says:
I'm so proud of myself, I desoldered some 8 pin SOIC's with a $16 40 watt soldering iron! They didn't even melt(I lifted half the pad on a couple pins, though)! My iron has a nice tiny tip, and i keep it cleen. That helped a lot!
Feb 25, 2008. 7:50 PMalex-sharetskiy says:
wow... i thought the brown capacitors were resistors, and the capacitors with stripes were diodes
Feb 16, 2008. 12:16 PM1up says:
Awesome! Great method for desoldering them! I may use this sometime.
Feb 15, 2008. 8:58 PMWirelessMonk says:
Excellent! I bought a few SMD LED laden gift cards for a $1.50. I figured at a dozen leds per card it was worth seeing if I could harvest them off the pcbs. Now I know how! Gracias!
Dec 27, 2007. 6:29 PMfingers says:
I do thr same as a hobby and keep the bad stuff out of the landfills..It also makes good art stuff..
Sep 4, 2007. 11:38 AMSawbones says:
check this link for storage
http://www.engineeringlab.com/supkiten.html
or you can do it on the cheap like me and get those small plastic coin holders for dimes....
Sep 3, 2007. 11:12 AMThe Real Elliot says:
This is a great technique. Complements the hot-air stripper gun method perfectly. (Like, when you really just want one piece out of a given area.) Thanks.
Mar 24, 2007. 9:27 PMlightpacker says:
Trust me on this get a cheap 15-25 dollar butane torch/soldering iron and if your desoldering parts i recommend getting good butane and just keep the torch constantly moving and the solder will easily melt Just get it anywhere but radioshack their torch's fuel tank is way too small i got a bernzomatic for 15 dollars totally worth it
Feb 25, 2007. 6:54 AMRagman says:
Ya'know, I just use a toaster oven, wipe 'em all of when the solders hot then sort it all out. I realy like you storage idea with the sticky tape.
Feb 5, 2007. 11:13 PMprimoescobar says:
This is awesome for those cheap bastards like me who can't afford a heat gun. This is great. Thank you.
Feb 5, 2007. 12:06 AMbmlbytes says:
I was about to say something about you breaking the IC. But if you notice, you hadn't goten to the circuit yet.
Feb 1, 2007. 2:31 AMdfowler7437 says:
I have an article and some pages devoted to heat gun scrounging. The following link leads to a How-To and FAQ section and a post about scrounging a rack mount router.
http://www.uchobby.com/index.php/scrounging/
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
