Remove these ads by
Signing UpStep 1Stuff You'll be Using
Either a desoldering iron, a soldering iron and desoldering pump, or a soldering iron with desoldering wick or braid.
Solder (It helps, trust me)
Helping Hands (Optional)
Magnifying glass (Useful if you're desoldering surface mount components)
PCB Board to get components from
Water Bottles (Optional, but you'll need them if you're making the containers)
For all other situations the solder pot is the superior tool when it comes to the task of component salvage.
If you want to salvage a large piece (like those IDE or those PCI-E connectors on old boards) and you do not have a desoldering iron, try using a heat gun and direct the heat so that the most pins are heated. Have the board attached firmly, upside down (components down, pins up) and using pliers, grab the components and pull it down slowly.
It may require patience though, since a heat gun does not heat as efficiently the solder as an iron does. However, once you are all setup, mass desoldering an old motherboard can go quite fast.
2nd Protip: For a workplace, I used a completely striped down computer case. I lay the board on the frame and arrange so that the component I want to extract is aligned with an opening (which there is everywhere when a case is striped down completely).
Good luck and have fun.
Thanks bro, I was looking precisely for a good technique on how to mass salvage PCB, which I too have lying around after dismantling just about everything.
I thought about putting the PCB in the oven, since the solder is eventually all molten, but then, how to get the components out, hmm, haven't figured out yet!
I prefer your way much better! +1
http://www.kpsec.freeuk.com/components/led.htm
