3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Salvaging a $1 Fake Shake Light
How to get upwards of $6 worth of parts from a $1 flashlight. So, if you bought one of these and feel ripped off, here is a nice way to make lemonade out of a lemon.
Step 1Shake it, BREAK it!
Shake it, BREAK it!
First, you need to unscrew the lenscap. Next, carefully give it one good shake and be prepared to catch the inner tube. I recomend doing this while standing at the foot of your bed so it lands safely on it.
54 comments
1-40 of 54next »
Mar 16, 2007. 7:46 PMinstructa-fan says:
actually it is magnetic. I used it to pick up little screws and other metal crap from under my bed!lol! can you tell i'm an instructable fan when I have screws under my bed!
May 19, 2008. 12:51 PMD34TH2U says:
I have a welder, soldering iron, LEDs, wire coils, and tic-tac/altoid boxes under my bed...doesn't everyone?
Jul 4, 2010. 5:05 PMhitachi8 says:
yes ,
Nov 14, 2009. 5:02 AMmattccc says:
lol!!!!
Apr 21, 2011. 1:29 PMtwighahn says:
lol
Jun 17, 2007. 12:10 AMgirrrrrrr2 says:
nope...
Feb 2, 2010. 6:19 AMWolley says:
I don't think there is a magnetic in this flashlight if it uses batteries and the author says it is fake. The real ones use a magnet, coil and cap. to store the energy. This one appears to be battery powered cheap $1.00 version.
Jan 6, 2010. 7:42 PMmysterio77 says:
 actually, the thing in the middle is a half-supermagnet. stronger than the average magnet, weaker than a supermagnet. how do i know? i have this exact model of flashlight. theres also a resistor in there if you get lucky
Jan 6, 2010. 7:43 PMmysterio77 says:
oh, and the screws? prob made of chromium or some other metal that isnt magnetic. supermagnet+magnetized screws=shattered magnet and/or screws
Nov 14, 2009. 4:58 AMmattccc says:
some of the shake flashlights are fake but not all of them
Nov 13, 2009. 6:35 AMdrakesword says:
Hey there,
the piece in the middle has to be magnetic ... otherwise it wouldnt be able to induce a current in the coil from changing emf. Also you forgot to mention the large amount of magnet wire you get from this too!
Oct 12, 2009. 5:41 PMColonel88 says:
Hey can't you charge CR2032 batteries?
Dec 3, 2008. 7:28 PMpower says:
you can also save the magnet wire. pretty useful too
Oct 28, 2006. 12:50 AMJack Daniels says:
Grr not beaing able to read these isn't helping
Oct 28, 2006. 2:41 AMwestfw says:
"View all steps on one page" is working...
Oct 24, 2008. 3:32 PMboznia says:
Having been fooled by this one, and done some internet research ( whilst having no real knowledge of electronics ), is it possible to simply replace the CR2032 batteries with LIR2032 rechargeable ones? I have what I would call a semi fake in that the 'slug' is strongly magnetic and the coil is attached. Without the batteries the torch works ( really dimly ) and you can see the light pulsing when you shake it. However shaking it for a long time does not really improve the brightness. Would it require more components added to the circuit if I swapped the CR2032 for the rechargeable LIR2032s??? Hope someone can help.
Oct 25, 2008. 12:56 AMboznia says:
Thanks Hoopajoo! Can you tell me which capacitor you used, and how easy it was to fit? I have done little electronics I am afraid, but am keen to make my semi fake light a real one if possible. Thanks, boznia
Oct 30, 2008. 1:46 PMboznia says:
Thanks Hoopajoo. Can I ask one more quickie? Should I go for the highest Farad possible? is it the voltage that determines the brightness of the led? Also it looks like the tube where the slug goes would fit two AA batteries really well so I may just go for that option if the capacitor experiment fails.
Sep 19, 2008. 4:05 PMzach911 says:
Take the copper off of the coil and go to a metal recycling place and they will pay u for it but its not much $
Jun 21, 2008. 12:20 PMA good name says:
Of course the coil's connected, it wouldn't work if it wasn't.
Jun 21, 2008. 11:11 AMA good name says:
I had one of those... destroyed the casing but it was fun.
Jun 20, 2008. 8:07 PMguyfrom7up says:
well, I just opened a real shake flashlight (got it at a thrift store for 50 cents) and I got: 1x 0.22Farad Supercap (yay!) rated at 5.5 volts 1x bright LED 1x Super powerful big neodimium magnet 1x coil (don't know what to do with it) 1x Reed Switch (to make the flashlight water proof they had a small magnet on the outside that slides as a power siwtch, which activates the reed switch, very cool!)
Jun 21, 2008. 8:46 AMguyfrom7up says:
my reed switch just broke... :( they are realy fragile, do not try and bend leads.
Mar 7, 2008. 2:13 AMrandempedestrian says:
The "coil" in one I bought from the "Dollar Or Two" by me is not even a coil of copper wire, but rather a wide, reflective, copper-colored, plastic ribbon of sorts. As others mentioned, the hunk of metal is not magnetic (well, barely). However, the LED in this light is extremely bright compared to the brightest white LED that RadioShit sells.
I think I'll but a few of these cheap, fake flashlights for the LEDs (since $2 is a lesser cost than a less-bright LED from RS... plus I get a free housing, mini circular mirror, and convex lens) and then then one real shake-flashlight, and I'll build a nice bright multi-LED flashlight of my own.
Dec 31, 2006. 6:49 PMplanes891 says:
ha radioshack near me has white leds for, wait for it... $5.29 lol
Oct 16, 2007. 5:48 PMegreen767 says:
same here
May 9, 2007. 8:32 PMHavoc481 says:
http://alan-parekh.vstore.ca/ has led's for $0.50
Oct 27, 2006. 6:30 PMTool Using Animal says:
I was wondering about this, I disassembled a student's light a couple of weeks ago to fix it for her (the switch got out of alignment) and I noticed that the magnet wasn't magnetic, but it was terribly heavy, I wonder if that's a lead slug?
Sep 19, 2007. 6:55 PMincorrigible packrat says:
Guess the Chinese had to put their excess lead somewhere, after they got caught painting children's toys with it.
Dec 5, 2006. 12:55 PMPogo says:
If not magnet and not lead, I hope its not depleted uranium fragments from some bombs sent back home to get even.
Oct 28, 2006. 3:27 AMMyself says:
After hearing about the fake lights, I tested a few at the local cheap-chinese-junk emporium. Their $2 version was a true shake light, it started flat and brightened when the magnet passed through the coil, and would really build up some power after a minute's frantic shaking. But even after 2 minutes of shaking with the switch off, it only gave 20 seconds of light. I'm guessing there's just not enough energy storage in their cheap caps. Be suspicious of any "shake-light" that glows when you first turn it on. Unless another customer was just shaking it, the capacitor shouldn't have much in it. Verify that shaking does actually make it brighter! You should also get a bright "spike" of light as the magnet passes the coil, if you tip it end for end with the switch on. Failure to behave as described means it's probably a fake.
May 24, 2007. 2:00 PM_soapy_ says:
Seconded, mostly. I find the good ones (I have two) hold charge for months, so a glow at power-on means little. However, shine it on something then shake it, and you will see the light get brighter as you do it. You can actually see a pulse effect if you shake fast and hold it fairly steady. The other test is to try and stick a paperclip or mortice key (generally steel) to it. (Note that most cylinder keys are brass coated with silvery coat, whereas all mortice keys are steel except for two manufacturers. The little steel rings that hold your keys in a bunch, however, are always steel.)
May 12, 2007. 12:40 PMmagician13134 says:
Where did you get one for $1?
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:Hoopajoo
USAF - Spec. Communications, Telemetry & Data Networking, Microwave Networks, Aeronautics Interests: Metal working, Electronics and Botany (especially wild edible plants, "Feed the world with weeds")
