3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Samsung Epic 4g Inductive Charger
Step 3The Soldering
The Soldering
This is the crucial point.... If you mess up here you can cause irreversible damage to your phone.... So please please please!!! Take your time and watch your heat!!! Do not hold your soldering iron on the board for to long!!! You can really shoot yourself in the foot... :D
This is rather straight forward and very small...
The two outer prongs of the micro USB connector are your power. What I did was melt a LITTLE bit of solder onto the end of my wires. I then came in with snipers and cut it in half... You really want as little here as possible... As you can see on my I had WAY to much even on my finished product and just decided it wasn't worth the risk to try and fix.
Ok... Now that your heart is racing... Double check your solder/wires are not touching other leads... This is simple... Just grab a razor and run it between your soldered leads and the stock ones.... If it goes with no problem you are set. If not... Well prepare to be in for some fun.... (I had to resolder the left one three times....)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:G4ry
