The Armor i built was a fairly simple design but due to my small body structure was a little difficult to form the armor. how ever it worked out and i only messed up once during the whole build process! (drilled the wrong holes in one of the armor panels.)
I built this for fun based on several other instructables and my wanting of a costume that i built from the ground up and designed myself as well as having a sweet costume for dragon con 2012 ;).
the total cost of this project was $110 and took just under two weeks by myself :)
the armor i made is made out of HDPE 3/8" or cutting board. this armor made from a design from a video game will be used in stunts with sharpened knives and swords and compared to other armor types of the period made out of the same material after the testing well be doing a "deadliest warrior" style challenge were we have a face off in the many armor and compete with real swords!
what youll need:
2 sheets of HDPE plastic or your choice of armor material. you can use ABS,Sintra etc. (noobies use sintra its easy to work with and cheap!)*** Some one mentioned that you can get used acid drums made out of HDPE and cut them out, that way the armor is already shaped and rounded.***
Lots of thread i used a 7/8" ribbed thread to thread the armor together and about 12 Spools of it.
sewing machine
thread
scissors
fabric (i used Brocade/Sari)
lighter for (burning the edges of the thread)
drill press
band saw
dremel
hot glue gun
sandpaper.
this is a moderate build took only two weeks at full time hours but it does require a lot of drilling and threading.
feel free to make your own changes to what ever you like! like paints, fabrics and threads!
feel free to ask questions and share comments with others! best of luck!
Remove these ads by
Signing UpStep 1: The Soft Goods (Robes and Pants)
you don't have to be a seamstress to do this part of the build, I'm not one that's for sure. go to your local sewing/crafts store and get a template for Bath Robes. use these templates and measure them to your body accordingly. pick some awesome fabric! what you see in my build is red with black Japanese writing and symbols. its called sari or Brocade, its a very light fabric and looks amazing in the sun light but be warned it is difficult to work with because its just like satin or silk.
there's not much to be said here just follow the instruction in the template and they'll turn out great! :D i did some edits on my pattern i made it a tighter jacket and made it shorter so it didn't drop down below my waste to far. you want it a bit baggy so don't tapper it.
for the gloves socks and sandals i just went to a thrift store and dropped 6 bucks for matching set.
pick your own colors and add your own trim to it to make your own flare!
Visit Our Store »
Go Pro Today »
pretty simple, just used a bit of epoxy and hot glue. im not sure what you mean by "latching it to the other i side" can you explain it a little more for me? :)
thanks!
For your helmet, it would look a little better and be a bit more accurate if the lamination are tied outward so it gets successively wider instead of inside so it goes towards your neck. It's why the flange on your helmet looks so narrow.
Also, where did you get the inspiration for this design? It's always nice to site your sources ;)
i agree on some of the armor bits needing to be more accurate but this was a 2 week build after all and not one of my major costumes. also the material chosen is incredibly hard to shape it to flange out like you mentioned and i also like to look up with out a band of plastic burrowing into the back of my neck and shoulders.
viola! http://www.instructables.com/id/Samurai-Costume/
http://www.japanese-armor.com/images/source/Samurai_Do_maru_armor_piece.jpg
I have made the chest plate armor with interlocking mats, it was pretty hard but people can punch and kick me with it on and it doesn't hurt.
They would not protect, and get wet very easily in your area or snow.
in battle the last thing you would worry about is getting your feet wet haha. :)
http://en.wikipedia.org/wiki/Sashimono
Could be a little taller than that or your pals won't see you in the battle field
Great Job !!!
yah i wanted to make it tall but going through doors would have been a bit of an issue haha xD
thanks!
