Step 4The Kabuto (Helmet)
After I cut the ridge off the helmet, I sanded it with a fine grit and used the same paint as the rest of the armor on it. We let that sit and dry until we finish the skirt for our helmet
The shikoro (skirt) was made almost the same as the shoulders and kusazuri. Only this time, we want the pieces a lot longer so they come around the helmet and just short of the visor. The top most lame of the skirt is going to have to have 3" extra on each side in order to have the curved back pieces that traditional samurai helmets have. As you make the lames , each will be longer then the last so to make up the difference in circumference since these will overlap. Ok, so you have all 4 lames curved after running your strips through the hot water and cooling them. (It helps to keep the helmet on the counter so you can judge how well it is going to fit) Before drilling these and painting these, you have to account for lacing space. The picture in MSpaint (yee-how!) shows how. After marking where your laces will be, you have to line up the marks for each line to drill them. Once you get your holes drilled, fit the top lame to your helmet and mark the helmet where the holes line up. Drill the holes in the helmet where the laces will attach the shikoro to the Kabuto. It laces in the same fashion as the Sode(shoulders)and Kusazuri(upper leg)I hot glued some of the top lame to the Kabuto so the laces didnt have to do all the work.
The Maedate you will have to find a shape for. There are some good ones online from real samurai armor or you can make one up. Just be sure to contour it to the front of the helmet and hot glue it on.
Add Comment
