Samus Aran Costume
28,069
288
23
Posted in CostumesGames
Introduction: Samus Aran Costume
About: I'm a senior at Harvey Mudd in Claremont California. This past summer I worked at Make Magazine. I love working out and eating well, and I enjoy concocting healthy recipes for not-so-healthy dishes (though u...
For Maker Faire 2011 our family built a Samus costume for my brother. It has over 100 arduino-controlled LEDs and sound effects.
I'll just walk through the individual components and say a little about each.
Arm Cannon
The cannon was made out of a piece of 3 inch (inner-diameter) schedule 40 PVC which we glued EVA (ethylene-vinyl acetate) foam to, covered in a craft sealant (called "Mod Podge Glue"), then painted. The front muzzle piece is just a 3-2.5 inch PVC adaptor with a piece of orange transparent acrylic glued inside. Behind the acrylic are two sets of LEDs, 6 yellow and 6 red, which are independently controlled by an arduino in the backpack.
Near the back of the cannon, there are two styrofoam* protrusions on opposite sides of the barrel. One houses a control panel that has buttons where you can 'unlock' the cannon by typing in a certain combination (once you unlock the cannon, you can shoot by pressing a button inside the PVC tube). The other has a speaker imbedded in it, which plays cool sounds from the game Metroid when you push buttons and 'unlock' the cannon with the right combination. Both of these are controlled by the arduino stored in the backpack (you can see the cables running from the cannon to the backpack in the main photo above).
Pressing a button inside the PVC tube plays a sound effect and flashes the LEDs in the barrel. If you hold the button down, and then release, it plays a 'charge up' sound effect and then a shooting sound effect.
The Backpack
I made the backpack out of vacuum formed plastic and some scrap PVC. The master mold for the vacuum forming was made out of styrofoam* covered with bondo. The backpack held all the electronics for the whole suit. We had a 9V drill battery in one "turbine" and the arduino and sound shield (which we used to power the speaker) were stored in the other "turbine".
The Chest Plate
The chest plate was also vacuum formed plastic. We also imbedded some LEDs by gluing them into transparent green acrylic, then gluing the acrylic behind the cut-outs we made in the chest plate.
Shoulder Balls
Making the shoulder balls taught us how to mold and cast with silicon and urethane resin. First we made a master mold with a large styrofoam sphere, foam core, plaster of paris, and bondo. Them we made a negative out of silicon, then cast the final pieces out of urethane resin. We also imbedded LEDs in the 'groves' just by drilling holes and gluing the LEDs in from the back.
The Helmet
We walked into a motocross supply sore and said "we want the cheapest motorcycle helmet you've got". They looked at us a little strange, but we explained that it was just for a costume, and one of them was actually really into Metroid and thought it was awesome that we were making a samus suit.
All three protrusions on the helmet are styrofoam* covered in bondo (the two 'muffs' near the ears on each side, and the 'ventilator' near the mouth). The tubing connecting these components is just electrical conduit. Aside from stenciling the correct visor shape onto the wind-screen and putting a little translucent green plastic behind the visor, that was about all we did for the helmet.
Body Armor
The rest of the body armor was either vacuum formed plastic, or just thin, painted, EVA foam which velcro-ed onto the black jumpsuit he was wearing underneath.
I made the molds for the vacuum formed pieces out of styrofoam* and this cool epoxy resin stuff called Magic Smooth that you can prepare in large qualities and then smooth onto your work with water until its really... smooth. Anyone whose worked with bondo knows that getting anything smooth or even requires a ton of standing. This resin stuff was great though because there was barely any sanding involved after it dried.
Once again, we imbedded LEDs into the vacuum formed pieces by gluing them into green acrylic, and then gluing those under the plastic.
* The pink 'styrofoam' we used was technically called EPS (extruded poly-styrene) which is very similar to styrofoam, but technically not the same. However, we did use actual styrofoam for the shoulder-balls.
Notes on Vacuum Forming:
We used 1/16" polystyrene plastic for all of our vacuum-formed pieces. Its really easy stuff to use, and pretty easy to find (we got all of ours at Tap Plastics). You cut out a section of the plastic, clamp it in a frame, stick it in the oven at around 225 F for 10 minutes, then press it over your master mold on the vacuum forming table.
Building the table itself is probably the most complicated part. We sort of just winged it with the design. Ours is just a 2x2 foot square box made out of MDF, peg-board, and some scrap 1x4 inch pine we had lying around. There are holes for vacuum cleaners on either side of the box. The idea is: when you turn the vacuum(s) on and press the oven-softened plastic over your mold, you complete the seal around the edges of the peg-board with the frame thats holding the plastic. Then, each hole in the peg board turns into a mini-vacuum cleaner, and the plastic gets sucked to the table. All air pockets between the plastic and your mold get sucked out. After several seconds, the plastic cools again and hardens, and you are left with a 'shell' of your master mold.
That being said, there are several things to consider when you make your vacuum forming table. Make sure that you calk the inside seems of the box before you completely assemble it, and when you screw the last 'face' of the box on, make sure to calk the joints so the box is air tight (aside from the holes in the peg-board). Also, depending on the strength of your vacuum cleaner, you may want to add 2 vacuum ports in your table instead of just one, you'll get stronger suction this way. Also since there is considerable pressure on the top and bottom of the table during the actual forming process, if you want to make a huge table (bigger than 2 by 2 feet), you may want to add supports periodically throughout the inside of the box so the top doesn't collapse when you are forming.
ThinkGeek Sci-Fi Contest
Second Prize in the
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    23 Comments
    looks like a very thorough costume, well done!
    OMG!! I am a HUGE Metroid fan so I would TOTALLY wear this
    Awesome!!! And good on your brother for not caring about "dressing up as a girl". Samus is a hero for all :)
    so, how does it feel when you roll up in a ball? I've always wondered how that works, does it hurt?
    I need that costume D:< but I don't have the skills to make it...
    Very cool project, but I don't see a materials list, so:
    1. What type and thickness is the plastic you used for the vacuum forming?
    2. What is the "cool epoxy resin stuff" you refer to for getting a smooth surface?
    3. What is the "craft sealant" you used on the foam?
    4. What is "EVA" foam?
    Thanks.
    Thanks for the good questions! I just updated the post with the answers, but I'll list them here too so you dont have to go back and dig around.
    We used 1/16" styrene plastic from Tap Plastic
    The brand is "Magic Smooth", but I'm not really sure whats in it... It works well though!
    It's called Mod Podge and it's used for doing decoupage-type projects. You can get it at Michael's or any craft store.
    EVA is ethylene-vinyl acetate, it's basically just a variety of foam-rubber that comes in a bunch of different grades, used for everything from tough floor mats to spongy padding. The pieces we used for the arm cannon were actual cut from an old camping sleeping pad.
    Why were you using the torch on the plastic while vacuum-forming it?
    Good question! When we take the plastic out of the oven, it's really soft and pliable because it's warm, so it responds well to the vacuum and sucks down onto the master mold. Sometimes it cools before it's finished though, and so there are often places around the edges of the mold that are not fully 'molded' in the plastic. If you leave the vacuum on and re-heat these areas (with a blow torch) then sometimes you can get the plastic to mold to the master mold a little better.
    This is greatness!!! Love the suit, I need to make this for my wife!
    Totally voted for you!
    Did one of you guys do that 3d model? Perhaps the found it on the web or extracted it from one of the games? Thanks! :)
    nice! you should make the led's do things though :) really easy with an attiny or arudino.
    That is too cool! Great job man.
    I don't suppose you can share that 3D model of Samus, can you? I would really like to get a copy.
    I just did, thanks for the suggestion!
    Fantastic job! I love to see all the family working together!!!! :-)
