Sand Fire Garden
Sand Fire Garden
So many people have hung out with the warmth and played in the sand of my wonderful Fire Gardens have asked me how they could make one of their own.
This instructable will walk you though the basics of building your very own Zen Fire Garden.
I’ve taken the guess work out of all the fittings and sizes and put together a few kits that I use all the time in my work. You will need to find or make your own container, and build a stand or a base.
Step 1Plumbing Parts
Plumbing Parts
You will needs some basic off the shelf parts to make a fire pit:
1) Regulator/hose 30 PSI (not a BBQ regulator) and a needle valve to adjust the flame size. I use brass 3/8 45deg flair fitting for the hose ends and the attachment at the fire pit.
2) Fire ring. This is the distribution system that is below the sand for your gas. If you have the ability to weld and make rings you can make your own using a 1/2 weldable (not cast iron) coupler in the center,  5/8 thin wall tubing and drilling 3/32 holes every 1 1/2". The ring should 1/2 - 1/3 the size of your container diameter.
Stainless steel will prolong the life of the ring especially during the winter when you forget to cover your pit in the first rain.
3) Fittings. A 1/2 NPT coupler (weldable), Brass1/2 to 3/8 45 deg flare (for attaching the hose to)(not used in this build), brass 1/2 NPT nipple (to attach the the ring to the coupler welded to the container)(not used in this build), brass1/2 NPT lock nut
4) BBQ sized propane tank.
I've put together an affordable kit of the basic plumbing supplies you'll need to build your own fire pit.
I offer several sizes of rings, stainless upgrades and fully auto systems for high end remote controlled fire pits.
Fire Pit Kit link
UPDATE:
I now offer a new bulk head coupler that works in materials upto 1" thick. No welding required! see the last 2 photos on this page
114 comments
1-40 of 114next »
Jan 30, 2012. 6:49 AM21bose says:
Just FYI, the kits sold from Form and reform have the holes facing up, and need to be changed with an allen wrench, however, I have not encountered any problem with the sand yet, except for people receiving 2nd degree burns from the flaming sand, lol.
Nov 20, 2011. 10:14 AMboothification says:
What about using a different medium for the filler? Instead of sand, maybe glass cullett... The propane shouldn't get hot enough to cause any melting, etc...
Oct 25, 2011. 8:14 PMmlacerda says:
I'm sorry if this has been already answered but, you said "Sand should be 3-4″ above the ring" How do you do that? Isn't the sand going to obstruct the ring'holes?
Oct 21, 2011. 8:40 PMbobthebuilder728 says:
Great instructable, im gonna make one
Sep 23, 2011. 8:24 AMdmiles3 says:
This is incredible great build, what was the cost?
Jul 12, 2011. 8:03 PMAlgag says:
Are you able to cook on this? Didn't see it anywhere and wasn't sure if the sand would give off some kind of cancer causing chemical *rolls eyes* or something of the same nature? If it is said somewhere, sorry for the comment.
P.S. Great 'ible !
Jul 28, 2011. 11:22 PMH3xx says:
I wouldn't cook with it because, well, sand burger. Howver a portable unit to take to the beach would be sweet. Though wind could be an issue.
Aug 1, 2011. 12:43 PMAlgag says:
I was thinking about this and then I started to wonder if you understood that i mean to cook something like hotdogs and marshmallows as if a campfire
Aug 1, 2011. 1:16 PMH3xx says:
Oh. I thought you mentioned actual cooking like grilling. :) As long as your sand isn't treated with anything, and you've kept the cats away from it it should be fine. Just make sure not to get any sand on anything you cook and don't drip anything into it. I'm quite sure a sand filled grease fire would be very unpleasant.
Aug 18, 2011. 5:07 PMdjenjen says:
Yeah, end Zen fire pit... commence gurgling spitting oil slick. Tho' ain't wood burning fires Zen in and of themselves? Just sayin'....
Aug 18, 2011. 5:02 PMdjenjen says:
I lived in Nepal for a time and they just burn small pieces of wood (any wood really; scrap tree branches etc) in steel bowls without anything else to gizmo it up. Burn the wood to create nice hot coals (where most the heat comes from anyway) and set grill top over it to cook stuffs. Propane is way too expensive in developing countries (here as well) tho' this fire pit ya made looks perty. If you're worried about a burn mark on concrete and don't wanna build a custom metal wrack to hold the bowl then I s'pose you could set the bowl atop a cinder block or two perhaps even with a piece of sheet metal to absorb some of the heat. I'm goner do that and set some really nice large stone chunks like quartz around the blocks to conceal the cement and the lower edges of the bowl itself then plop a bunch of tree roots around the makeshift fire pit n call it home for the winter! ;D
Aug 2, 2011. 1:45 PMElectorials says:
In the video it looks really cool ;-)
I've never seen anything like this, it's awesome :D
Jun 5, 2011. 6:23 PMonemoroni1 says:
What about using natural gas running a line from the house? I've repaired gas fire places by just using a six inch nipple, drilled holes and appropriate pipe fittings to connect it.
Jul 9, 2011. 6:39 PMZachTriplett says:
I literally just finished making a natural gas fire pit in my back yard by running pipe under the ground to it. It seems to be working just fine! :)
Jun 26, 2011. 8:04 PMsciman1 says:
Turns out, you can actually use a bbq grill regulator, the adjustment is under that cap. better off having it lit without sand while adjusting SLOWLY, if you adjust it without it lit you run the risk of damaging something when you do light it. just FYI
Apr 12, 2011. 9:42 AMjyoung-1 says:
Could you use a standard burner from a bbq grill?
Jun 6, 2011. 1:59 PMKT Gadget says:
You could use the burner where the flames come out, but for the hoses from the BBQ grill, those will probably get you a different result than this setup, but thats just based on my observations, I have not tried this out myself so don't take my word for it.
May 6, 2011. 2:37 PMgjm says:
I bought this kit a few months ago and finally finished building the bowl last week but I think I have a problem.
When I use it the regulator and hose get so cold that within a few minutes the regulator and hose get completly covered in frost.
I have a propane grill, mosquito magnet, and propane turkey fryer and none of these exhibit this so it doesn't seem normal to me.
Anyone have any idea why this is happening? I stopped using it because I don't know what's going on with it.
Thanks all.
May 15, 2011. 5:14 AMgjm says:
Hi again,
You are correct, it was the full tank causing the hose and regulator to freeze. I used a bit of the gas cooking a meal on my grill and tried it again and it's fine.
thanks.
May 7, 2011. 5:25 AMgjm says:
Actually this is a brand new tank I just bought because my old one had expired.
I have another older tank that was just filled also so i'll try that and see if I get different results. I'll put the new one on my grill and use some of the gas too.
Thanks, I'll let you know what happens.
Apr 11, 2011. 1:17 PMjohnatwork says:
What keeps the flame from igniting in the hose and getting back to the tank?
Apr 12, 2011. 10:09 AMjohnatwork says:
Thank you for your reply. Nice instructable!
Apr 25, 2011. 11:51 AMmitchell12 says:
Exact same thing as every propane bbq and blow torch, it's quite safe actually. Nice Ible.
Nov 29, 2010. 11:56 AMnitsuj1098 says:
I can't seem to find the burners you use at any local place. Is there something similar that is locally sourced that will work? Does the burner have to be round?
Aug 26, 2010. 3:41 PMeulaliaaaa! says:
errmm.. Zen? What is that? I just think that this is a cool fire pit thingy. Great instructable by the way!
Aug 26, 2010. 3:45 PMeulaliaaaa! says:
Although I am guessing that it is some sort of religion...
Oct 21, 2010. 1:56 PMcupebill says:
Not even close to a religion. (Unless, of course, you don't understand it.)
The fire garden, however, is very zen for those who want to take it that way!
I'll be building several as gifts.
Oct 17, 2010. 5:56 PMKruegem says:
very nice. very mellow looking. i makin it
Feb 25, 2010. 3:01 PMajohnson153 says:
Wonderful Instructable. Two questions 1) Could one just use one of those firebowls you can buy at the home depot to keep from having to fabricate a base?
2) Also would it be possible to somehow connect this setup directly to a Natural Gas line for a home. Most of the homes in our area run on NG so it would be ideal to have it set up so we would not need a propane tank. Ok, So I lied about only having two questions the third question is how long can you usually run this setup on a single tank. I was thinking of doing this on a covered patio in order to prevent there from being a lot of smoke buildup.
Aug 2, 2010. 1:57 PMbeyoung99 says:
I just finished one of these out of a standard cheapo copper firepit - works great! Already had the fire pit, bought recently from Academy Sports for ~$30 on sale. FYI - with respects to originator, my goal was to build from big box hardware store parts (Home Depot / Lowe's), i.e. no internet or specialty plumbing parts. - copper firepit is about 30" OD, 26" ID - distributor is soldered 3/4" copper tubing, about ~ 11" square and all T's and elbows (I'm bad at bending tube). Works fine with round firepit - copper tube through bottom is 1/2". Used electrical conduit fitting (kind with rubber grommet inside) to pass through bottom of pit, and 1/2" was largest they sell. Also used large conduit washers and plumbers putty to seal. - only component I had to buy online was regulator. I live in a big city, but NO ONE sold the recommended 30psi regulator. Online wasn't too bad $$$, and came with needle valve already installed. P.S. suggest trying a 20psi regulator, as my 30psi doesn't have much adjustment range before regulator shuts off gas (not enough back pressure).
Aug 5, 2010. 2:20 PMbeyoung99 says:
No doubt Jon. Lesson learned is probably to fabricate entirely out of 1/2" tube and/or drill smaller holes to generate more system back pressure on the regulator. I like the prefab kits you are selling and wouldn't be surprised if I spent same $$$ building from scratch myself
Feb 26, 2010. 3:13 AMducttapechemist says:
How long would a small propane tank(like one you would take for camping) burn in one of the smaller models?  I think a small contained unit would be fun to make. Maybe get a stainless steel cylindrical trashcan and use that as a base and the compartment  for the tank.
Mar 6, 2010. 9:26 PMspylock says:
That was going to be my question,if anyone knew how long one of those small camp stove tanks would last.I was going to do a water feature with fire on the water,or do one with a base simular to yours and use shattered saftey glass instead of sand,I want the fire to feflect off of something.
Aug 2, 2010. 2:12 PMbeyoung99 says:
I've built one with sand (very cool), but want to step it up a notch and try colored glass. Two questions please: 1. how thick does the glass layer have to be? 1-2" on top of sand or replace all sand with glass? 2. where can I get the colored safety glass on the cheap? Have seen online, but only other thing I can think is an auto glass shop (clear only!) P.S. tried with 1/2" colored glass squares I found at a Hobby Lobby, but did not work at all - think I need really small pieces like broken safety glass to get that "fractal" effect
1-40 of 114next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
108
Author:jonsarriugarte
