Step 2Container for the fire pit
In addition to the plumbing parts you will need a container that is able to handle high temperatures and be fully sealed underneath (leaks or drain holes will also allow gas out and fire where you don't want it). The bottom 6-8" of a 55 gal drum works good. I have also used a wok, Stainless Salad bowl, or dog bowls. Stay away from painted steel, aluminum, and galvanized steel as these will release fumes or melt. The weldable coupler can be welded though the bottom, I also sell a bolt on coupler, or a lock nut (see step 4).
I have seen people make these in cement, ceramic pots, and I have used mine with a 3' pipe added (to move the hose away from the heat) right in the beach sand.
comment
Add Comment
jonsarriugarte (author)
says:
says:
says:
Add Comment
