Sandals from an old auto tire, pt. 2
Improve the comfort and look of the straps for your tire sandals.
Step 1Make the basic sandal
Follow cthoyes fine step-by-step to get the basic sandal from a tire, but skip the tabs on the sides and back of the sole. You won't be needing them. You'll find it is much easier to cut out the sandal without the tabs for straps.
33 comments
Sep 21, 2009. 6:03 AMgaspargs says:
how did you cut the tire?? Is it A steel radial tubeless? or a nylon bias tire?? This sandals are great!!!
Sep 4, 2010. 8:27 AMBromKim says:
Forget the chisel if you have a reciprocating saw (a.k.a. Sawzall) or a medium duty jigsaw. Steel belted radials cut easily with either, using a metal cutting blade.
Jul 13, 2008. 7:55 AMBECKY2 says:
QUESTIONS. THE NYLON STRAPS,HOW WERE THEY MADE? WERE THEY ALREADY MADE FROM ANOTHER TYPE OF SANDLE OR DID YOU MAKE THEM? IF YOU MADE THEM HOW DID YOU DO IT AND WHERE DID YOU FIND THE NYLON TO MAKE THEM? THANKS B
Aug 29, 2010. 6:53 AMKittyF says:
or salvage the whole assembly from a worn out backpack
Aug 27, 2010. 8:28 AMtemetnosce says:
I have access to old non-steel belted tires if anyone is interested. Shoot me a message....
Aug 2, 2010. 4:05 AMeric55 says:
Hi, great instructable. I grew up in South Africa and the blacks over there make these sandals (guaranteed for 10,000km) they used inner tube as the straps fitted the same way as thongs (Australia) or flip flops or slip slops. My father over there will find out how they are fastened and I will let you know. BTW inner tube is good because it has an elastic quality.
Apr 21, 2010. 12:36 PMexodous says:
I was wondering if your tire had steel radials.  I've been looking around and pretty much all modern tires use them.  I found some riding lawn mowers that didn't have steel radials but they are thinner and not as rigid as car tires.
Anyway, if they did how did you cut through them?  Does the chisel method you describe work for steel radials?
Oct 3, 2009. 2:22 AMwhisperingslim says:
them soles r v tuff cut in 2 sole half way down below nylon thread .then up cinch
Jul 23, 2009. 9:50 PMOlaf_First_962 says:
With the rubber straps going through the bottom like that, do they tend to wear first? Would it be too hard to angle the holes out the side so you don't walk on the bottoms of your straps? Or would that cause the sole to separate? After a few more "miles" on your test drive, please let me know!
Jul 24, 2009. 6:09 AMOlaf_First_962 says:
Thanks!
Apr 24, 2009. 6:18 PMbodgermorg says:
Pop rivets work great too on the nylon webbing. Your wire stitches would be much easier to replace though...and cheaper.
Oct 28, 2008. 11:32 AMuktena says:
My feet swell a lot in hot weather. We could also put velcro strips on the straps instead of buckles for fast, easy adjustments and less rubbing on the skin while walking. Just an idea! Thanks for all the great info!
Oct 18, 2007. 5:02 AMfegundez1 says:
i have a pair of mex sandals i bought in t j over ten years ago,they are indestructible...except the craftsman who made mine used some sort of heavy duty glue to attach the straps and the leather lining to the sole.the glue eventually wore out and the straps came out so i had to re-attach,but only after about four years
Jul 21, 2007. 3:39 PMogeezer says:
I used to make Ho Chi Mihn sandals for all members of our family, from the original design I'd seen countless times while serving in Vietnam, but micmac's design is better, particularly the strap assembly, illustrating Yankee-ingenuity at its best. Great idea, I'll have to try it out with my next tire change.
Aug 27, 2006. 2:51 PMnoah joad says:
Hi, micmac.You said you used steel belted tires.How did you manage to cut them? I want to make me a pair of tire sandals, but tires without steel seems to be hard to find.
Mar 25, 2007. 2:47 PMPkranger88 says:
Non-steel belted tires can be found very easiliy. Go to your local ATV/Outdoor powersports shop and they will probably have tires just laying around. ATV tires are usually steel free to allow for flex as they travel. Superswampers are steel-free I believe. If nothing else, get yourself some Firestones. They should delaminate easy enough.
Mar 27, 2007. 10:58 AMPkranger88 says:
I happen to have some laying around. I'll see about getting some made and posting the results
Jan 24, 2007. 6:59 PMsandallover says:
great sandals.I have a pair of leather toe loop sandals with tyre soles
Sep 14, 2006. 2:31 AMdanburite says:
noah- you can cut steel belted tires with a carbide hacksaw blade- it helps if you lubricate the cutting with drops of water. this project is also covered in "steal this book", along with lots of other neat stuff. diy data that predates the web...
Jul 6, 2006. 12:56 PMbowdenja says:
Check out this site. He has an idea that ellinates punching the holes for the straps. He just integrates them into the sole.
http://www.hollowtop.com/sandals.htm
john
Jul 2, 2006. 12:59 PMlaernmoer says:
you could do the mexican method with their huaraches: 1) tack/glue thick leather to the top of the sandal to make it more comfortable. After a few months of wearing them, you can't tell your foot from the sandal. 2) the straps could be nailed to the rubber - I see you're thinking Teva, not flip-flops. Anyone else designing their own shoe, I would recommend noting how many huaraches are designed - this is probably 50+ years of trial and error practical research. Teva has orthopedists and $$$ to test a comfortable design. Ignore this comment if you're happy with this design. They definitely work - my friend's had his huaraches for 3 years and swears by them.
Jul 1, 2006. 3:30 AMJambe says:
Hey, this is really neat. Would it be possible to cut some strips of the tipe that were, oh 2-5 inches in width, and attach them via stichtching just like the blue strap closest to your toes? That would make the sandal into a slip-on, with a wider slot in the front so that it doesn't fall off readily. You could probably even cut ventilation slots in it!! Awesome idea. I might have to try this myself!
Jun 30, 2006. 9:50 PMmpap89 says:
he could have used an awl for the stitching on the sandle strap to the rubber.
Jun 29, 2006. 4:20 PMradiorental says:
awesome!! could you not stitch the webbing directly to the side of the sole?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:micmac
I'm an incurable tinkerer and builder and will often spend way too much time and money on whatever project is on the radar today.
