I made it at TechShop http://www.techshop.ws
If you have a 1/3 sheet or 1/4 sheet finish sander, then you know that pre-cut sheets of sandpaper can be purchased, but how many times have you cut your own from a full sheet? You probably cut it crooked with a utility knife, dulled your scissors, or tore the sheet.
Well not any more. Now you can easily cut perfectly straight 1/4, 1/3 or 1/2 sheets every time.
Materials needed:
Scrap 3/4" plywood, particle board or MDF
(1) 10" hacksaw blade (longer blades can be used, but you will need to adjust the design to fit.)
(2) #6 x 3/4" round head wood screws
Tools needed:
Laser engraver/cutter (available at TechShop)
Sanders
Screwdriver
Step 1: Layout
Sketch a layout, such as the one shown in this step, to mark the proper sizes for the different size sheets, relative to the cutting edge of the saw blade.
To save yourself a step, you can also download our .DXF and CorelDRAW files at http://www.lime3D.net/instructables/sandpaper_cutter.zip
anasdad says: Apr 27, 2013. 8:56 AM
Not exactly rocket scientist, but an outstanding job! I will be making one for my shop. thanks for posting it!
Ken
FN64 says: Jun 27, 2012. 1:06 PM
I've dulled my share of utility blades.. I LIKE IT!!!!
Gonna have me one of these by tomorrow afternoon.
Thanx..FN
coolbeansbaby68 says: May 27, 2012. 4:37 AM
Pretty smart idea!!
lime3D (author) in reply to coolbeansbaby68May 27, 2012. 5:29 AM
Thanks. You could also skip most of the construction steps, and just screw a hacksaw blade to your workbench, and draw a few guidelines. But at least this version is portable.
Denger says: May 21, 2012. 1:16 PM
Simple yet effective! Nice 'structable.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
