3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Satellite Survey Tool for FTA dishes & others
When installing a satellite dish, one of the most difficult problems is determining where to place the dish.  If the dish is placed in the wrong spot, you will receive no signal due to trees or buildings blocking the signal.  You could purchase a special SITE SURVEY tool but they cost about $200 dollars!  I built my own site-survey tool, and am quite happy with it.  I built several other site survey tools, but they were too large or required LEVELING.  This one uses GRAVITY to hold a string vertical as a reference point... instead of a leveling bubble. So it is much easier to use and more compact than others i have built. It is also "all-in-one" rather than a separate COMPASS and INCLINOMETER.  Once you get the parts ready, gluing it together only takes about an hour.  Once completed, you can look right down the waterpipe to the "exact" spot in the sky where the satellite is located!  So let's get started with the build.
Step 1PARTS NEEDED.
PARTS NEEDED.
Items you will need are very inexpensive.  You probably already have some of them around the house.
     1 compass that has degree markings zero to 360. and a sighting glass.
      1 childs protractor.  Mine was same size as a computer CD. Lucky me.
     1 half-inch plastic PVC pipe. cut into 3 pieces.  Length is not real critical. I used a piece
                    12 inches long, another one 6.5 inches, and a third one about 1.5 inches.
      1 end-cap for pvc
     1 plastic "tee" fitting
     2 pvc "splice" fittings
      Some string
      1 cotter pin
       5 or 6 inches of solder to wrap around the cotter pin.
      a hot-glue gun and 3 or 4 glue sticks
       a piece of sandpaper to sand off the lettering on the pvc pipes.
I assembled the unit using GLUE rather than screws because metal screws may be magnetic and would upset the accuracy of the compass.  If you use any metal near the compass, be sure you use BRASS screws as they are not magnetic.
5 comments
Jan 3, 2011. 2:54 AMlemonie says:
I like it, way to go not-spending!
L
Jan 12, 2011. 7:23 PMSteampunkManiac says:
Hey, Lemonie!
S
Jan 13, 2011. 12:34 PMlemonie says:
Hay!
L
Jan 4, 2011. 10:50 PMComputothought says:
Cool idea. Will have to get out my old compass to try that.
Jan 4, 2011. 5:31 AMijibang says:
you have made it so simple and original. thank you very much for sharing. i am going to make one. thanks again.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:framistan
I like building things. I like to experiment with alternative methods of heating and cooling houses.
