Sausage Stuffer
 by spike3579
Contest WinnerFeatured
Step 3: Top Bar
My top bar is made from a piece of Ipe (super dense tropical hardwood) salvaged from a piece of decking.  You can use anything that is available.  The wood is threaded for the plunger so the stronger the better.
  1. Cut the wood to 2" x 7 1/2".
  2. Drill two holes in the ends just like the ones in the base.   Place them 5/8" in from the end and centered on the width.  Same dia. as the holes in the base.
  3. Drill and tap a 3/8" hole in the center.
  4. Sand the wood and lightly round the edges and corners so it feels good in your hand.
  5. Apply a coating of mineral oil.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
