3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Save $200 in 2 minutes and have the worlds best writing pen
Step 8Dial 911
(Due to the violent nature of this step, we have not included a picture) Using any sharp implement (scissors, knife, axe, etc) cut the refil to be the same length as the original ink. (please use adult supervision)
27 comments
Jun 24, 2011. 12:08 PMPlo Koon says:
At the sight of the knife, the pen screamed," AAAAAAAAAAAAGGGHHH! NO! NO! PLEASE, NO!!"
But alas, its cries and pleas for mercy did not soften the Instrucableist's cruel, stone heart.
As the knife sawed through the defenseless pen, horrible screams of pain pierced and rent the air, and yet the brutal Instructableist was deaf to them.
Jun 24, 2011. 12:26 PMSteampunkManiac says:
U IS SPOOKY!!!!!!
Jun 26, 2011. 1:46 PMPlo Koon says:
Thank you.
Sep 18, 2011. 1:24 PMaccount3r2 says:
LOL
Feb 1, 2012. 1:14 PMninjasamurai says:
Yay now lets start sawing pencils for the sound it makes... MWHAHAHAHA
Jul 16, 2007. 11:31 AMwetware says:
I should have just bought the Mont Blanc: my dentist is going to charge $425 for the repairs to my teeth.
Apr 20, 2011. 4:34 PMSteampunkManiac says:
ROFLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL!
Dec 13, 2009. 3:17 PMTheRevisionist says:
wait, so now i have to find an adult? its gonna take like forever for the five year old i just made to be an adult.
Mar 21, 2011. 11:37 AMChimex14 says:
ROFL
Feb 18, 2010. 3:41 PMfoxtrot4697 says:
lol. If childs age goes above 5 redo step 5
Feb 17, 2010. 8:41 AMsomeniceguyon says:
lol omfg, thats great
Dec 9, 2009. 2:26 PMRunsWithExplosives says:
I didn't know adult supervision was sharp.
Dec 9, 2009. 9:08 PMwingsgtrfrk says:
dang it! and I thought adult supervision was SAFE!!!!!!!!!!
Jun 16, 2009. 3:37 AMarduinoe says:
ITS PEN MUTILATION
Sep 11, 2009. 7:12 PMsanty22 says:
is that the name of a band or a new kind of porn? 'cause it sure sounds like one!
but somehow its funny ..............
Aug 23, 2009. 12:38 AM(seabear) says:
hee hee, dead pen!
Sep 1, 2007. 5:54 PMkb8dnr says:
An alternative to cutting the top off the mont blanc refill is to use a two bit o-ring as a spacer to extend the G2 body to accommodate the longer mont blanc refill. Unscrew the pen, and place the o-ring over the lower half of the G2 pen body just above the rubber grip. I found my o-rings in the Sears Hardware plumbing department. They measured 5/16" ID by 7/16" OD by 1/16" thick, and were in a package marked F80 that contained four o-rings. An added bonus is this modification is reversible -- just remove the o-ring. Also the refill can still be used in a mont blanc body... Enjoy and Happy Hacking!
Aug 31, 2008. 8:23 AMlobo_pal says:
Great idea, kudos.
Jul 21, 2007. 9:24 AMkittykat123 says:
A simple emery board will do, cheap and easy just file it down...
Jul 21, 2007. 5:46 PMfungus amungus says:
A concrete sidewalk works, too.
Jun 1, 2006. 1:01 PMlyndefan77 says:
I found that a boxcutter did the job remarkably well. I just held the pricey refill next to the cheap one on my desk, and gave the pricey one a bit of a bris to match the cheap ones size. With the boxcutter it just clipped right off. I thought I may have to saw it a bit but it cut through the plastic very easy.
May 30, 2006. 3:54 PMnemroff says:
woozy!
May 30, 2006. 3:51 PMnemroff says:
using a dremel isn't any better than using a hot knife, both melt the plastic from the heat, both make you woozy. YAY WOOZY!
Apr 22, 2006. 2:23 AMhazaelox says:
Perfectionist: LakeLivin ;)
Apr 20, 2006. 12:18 PMDougmeister says:
Blue plastic. Black, in my case. Dremels were made for this type of work :-)
Apr 19, 2006. 3:47 PMLakeLivin says:
Or, do you mean cut the blue plastic at the end of the Mont Blanc refill to match the overall length of the G2 refill?
Apr 19, 2006. 3:29 PMLakeLivin says:
Again, for clarity, do you mean "cut the threaded portion of the Mont Blanc refill to be the same length as the threaded portion of the original ink refill"? (the refills themselves look like they are the same length to me)
Apr 17, 2006. 5:31 PMMatt23 says:
couldn't you just use a file instead of using such "dangerous" things
Apr 17, 2006. 4:11 PMForrest O. says:
plastic fumes are known to cause triple-clicking the post buttons
Apr 17, 2006. 9:59 AMxasx says:
plastic fumes are very dangerous
Apr 17, 2006. 9:56 AMxasx says:
Apr 15, 2006. 2:45 PMsg8_tau says:
What I like to do when cutting plastic is heat up a knife in the gas flame of a cooker then use the hot knife blade to do the cutting. (Just watch out for the plastic fumes unless you like that woozy feeling.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:kingant
nothing anyone should be interested in...
