Save Battery on IPad/ IPhone
Published
Introduction: Save Battery on IPad/ IPhone
About: Young maker
Step 1: Getting Rid of Open Apps.
Double click on the home button
Step 2: Get Rid of Them
Swipe up to close apps
Step 3: Another Step
Go to settings.
Step 4: Turn Off Bluetooth
To save extra battery turn of Bluetooth
That's the end
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    5 Discussions
    Some of those settings (bluetooth, wifi, brightness, etc.) are available in iOS 7, if you double-press the home button, then swipe up from the bottom of the screen. You can easily switching those things back on when you need them.
    In the Settings/Accessability, there is a way to invert the screen which might (might) save battery but making white black-- but not sure.
    Also, if ur device is jail-broken go 2 Cydia n install Bloard! It makes your keyboard a dark gray instead of bright white! It won't make a lot of difference but it helps!
    How about turning down the screen brightness a bit. Might help a little since the screen is the highest draw on the battery.
    lee547
    4 years ago
    Really?
    Thank you for commenting
