Remove these ads by
Signing UpStep 1Ingredients / Equipment
3 lb can of Hops flavored Malt Syrup
4 lbs Cane Sugar (approx 2 cups to 1 lb)
1 Pkt. Beer Yeast (or 2 ¼ tsp Baker’s)
5 Gallons Water (approx)
1 ¼ cup Cane Sugar (for priming)
4 cups Water ( for priming)
Equipment
2 Fermentation Buckets w/ lids (5 gallon)
1 Airlock w/ Rubber Stopper
53 12oz Bottles
Crown Caps
Bottle Capper
Siphon
Sterilizing Solution
* (if using bleach be sure to rinse well with water after sterilization)
![[Video] Homebrew Beer](http://img.instructables.com/files/deriv/FAL/FAV9/IMREYF7IB7B/FALFAV9IMREYF7IB7B.SQUARE.jpg)
A five gallon bucket will not hold five gallons of fermenting beer. There's not enough head space for the initial fermentation. You can still use the 5 gallon pail if you use a blow off tube instead of a fermentation lock. Take some clear vinyl tube and run it into a large jar, keeping the end under water. When the beer foams, the foam will go out the tube into the jar.
You can sanitize your bottles in the dishwasher. Put the wet, clean bottles in the upper rack, and use the heat/dry setting.
Notwithstanding what I've said, if you've been able to brew like this without incident, great. However you brew, keep the same process between batches. You'll increase your odds of a good result.
3.3lb can of hopped extract $17
Dry beer yeast $2
Bottle caps $2
total ~ $27 for about 5 gallons, which should yield 52 - 12 oz bottles
$27/52 = $0.52 per bottle of beer, not counting your labor. So ~$3 per six pack.
Of course, this is a tad more deluxe than the original poster's recipe, but I won't use bread yeast to brew with. I don't know where he scored the $9 can of extract from.
I do tend to figure my time in, so I don't home-brew even though I've helped make a batch or two in my youth. Yungling is like $17 a case around here.
I do see a slightly larger savings spread if you do all grain brewing (upps the complexity quite a bit, but people swear the taste makes it worth it.) Also, I'd be a tad worried that I'd drink all my savings, or start buying kegs, taps, growlers, etc..). Here, 12 pounds of grain at $1-2 per pound (hint: buy in bulk) replace the extract and most of the sugar. You probably want to buy some hops to add in also.
Made 5 gallons of a good red ale and used the spend grains for baking.
I agree, it takes a considerable effort and will not pay for itself until many many batches are made (and drunk). The reason I love to home brew is that "I made this" satisfaction. I can make what I like to drink and it's a good excuse to have the guys over and drink some brew while we make more.
This basic recipe may spark an interest in home brewing and makes the process look doable with a minimum mount of effort.
For someone like me, it seems like an easy way to get into the hobby, and I comment the author on that.
Home brewing can be as simple or as complicated as you want. I learned on extract kits, then "graduated" to partial grain kits and now I'm doing all grain recipes from books and other information sources. It's a great hobby and I encourage everyone to give it a shot.
