3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Save Some Water...With Water!?
The Toilet Buggy is a device that will save you a LOT of water from your toilet. Even better, there is a device at the top that, when you need to change the water, will enable you to take it out without dipping your hands in to touch the water. It is basically a bottle that displaces water and so, the tank doesn't fill as much.
Okay, I have to admit this is one of the coolest projects I have built.
A. It's green
B. It saves Money
C. It I get to have a tasty (depends on what you define as "tasty") drink before I get started
D. I Made It
Step 1Retrieve the Necessary Components.
You Will Need:
A bottle of water
A paper clip (Or wire.)
A Pencil/Pen (I'll get into details later.)
A toilet
An essential tool to this project:
 Pliers
13 comments
Dec 3, 2011. 7:41 PMrimar2000 says:
Interesting, but the advantage is not so big as it seems. If you reduce a lot the water flow (this is not the case), maybe it could be insufficient to carry the waste along the pipeline ALWAYS. A day you could find an ugly clog! It will cost a lot of work and/or dollars!
Dec 4, 2011. 5:26 AMrimar2000 says:
You are right, I only did the comment because some people could think "saving 2 liters each flush, I am more ecologist".
I think a day will come when the potable water will not be for that things. People will have two water pipelines, one for potable and other for "grey".
Pardon my poor English, maybe some words or phrase are unintelligible.
Dec 27, 2011. 8:08 PMJehu_McSpooran says:
No, your English is quite good and I can understand your two posts perfectly.
Yes there has been a bit of a problem with the 'dual flush' type toilets. As you said, due to the reduced water flow from using the half flush, clogging problems can and have occurred.
This is basically doing the same things as a half flush.
If you have a dual you could have a flushing policy. After 2-3 #1's mellowing, give it a half flush. After a #2 give it a full. You'll save more water in the long run and keep your home plumbing clear.
Dec 6, 2011. 3:40 AMdarthdredge says:
It seems an instructable has already been made for this: http://www.instructables.com/id/Save-the-bottle-save-water/
(posted Jan. 31, 2009)
Dec 6, 2011. 8:38 PMdarthdredge says:
No it's not.
Dec 9, 2011. 9:17 PMRobot Lover says:
blinkyblinky's version is actually much more updated than the earlier stated instructable. It goes into much more detail and has clear pictures. So, blinkyblinky is correct.
Dec 4, 2011. 12:38 PMgeckomage says:
this is actually a good idea. ive seen toilets that also raise the drain hole so they dont need to fill as much each time. although i myself use a power flush toilet because i am a big guy and have been known to take some notorious porcelain shattering dumps :P still a good idea though! :D
Dec 5, 2011. 9:29 PMgeckomage says:
sorry if this comment is socially unacceptable xD but i really dont have much of a sense of awkwardness :P so i will just say that i have clogged said powerflush toilet with JUST the waste before. no paper yet xD so i think i need every extra bit of flushing power i can get :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:blinkyblinky
If you want me to build something...I'm open to ideas. I like to hack with electronics, mix with chemicals and play with ideas. My motto? "If you want something to be done in this world, you must do i...
more »
