Clean water is more valuable than most of us realize.
Clean water requires energy, so by conserving water, you're also conserving energy! You can help minimize its waste by installing a foot pedal to control your kitchen sink. We're going to install a couple of
solenoid valves under your sink, and wire them up to a simple pedal. It's easier than you think, and you don't need any plumbing or electrical experience to do it. So, let's get started!
(If you like this Instructable, please vote for it! If you don't like it, please
vote for it anyway leave feedback below so I can make it even better.)
The heart of this project is a
solenoid valve. Very simply, these are small bits of pipe that have a valve that will open or close when you apply electricity to them. I picked these up on eBay for about $15/ea (here's a
search link to help).
Solenoid valves have a few important attributes:
- the type of voltage required to activate them
- whether they're open or closed when they're unpowered, and
- the size or flow rate they will support.
For this project, we're going to want a pair of 12V DC, normally closed valves that will support about 3 GPM (gallons per minute). Typically, the larger diameter of the "pipe", the larger the flow rate. I went with 1/2" solenoid valves, and they're more than adequate for this project.
You can buy some spade electrical connectors that crimp onto the wire and then plug onto the solenoid instead of having to solder them. They are much easier to remove if you ever need to replace anything.
I always wanted a similar device. I feel stupid for not building one before. I had this knowledge, but never thought about it. Thanks for the instructable. I'd make one eventually.
Here's an idea that I tried and works like a champ.
I wired both the hot and cold solenoid together (in parallel) to a single doorbell button. I mounted the button behind the cabinet door under my sink such that it holds the cabinet door open just a small fraction of an inch. When I need water, I push the cabinet door forward with my knee which depresses the button and closes the circuit. The volume and temperature are controlled with the faucet handle, the flow is turned on and off with my knee. It's nice that no switching device is visible to the casual observer in the kitchen.
Have one for several months now. Does not consume power and installation is a cinch with no plumbing experience needed.
Check out http://watermiser.hpage.com
Couple of questions: Think a brass bodied valve might be worth an extra fifteen bucks? And. . . I will install a gfci outlet and a small transformer (doorbell? suggestions?) . Would it be worth the extra complication of switching this outlet to save energy?
Also I am considering tossing in a couple more valves--they are so cheap-- and hooking them up to a pull out hose with thumb nozel. I could charge it with a wall switch and set the temperature (more or less permantently) with a couple of ball valves under the sink. The idea is to avoid having the hose under full time pressure. Anybody have any thoughts?
Thanks a ton,
Willy
You should be able to find a DC "wall wart" that would be compatible, if you don't have one lying around check Radio Shack or a similar place. I'm guessing that having the adapter on a wall switch might end up making it a little harder to use (one more thing to remember). On the other hand, you could always just leave the switch on, if it turned out to be a pain.
I've been looking for some different valves for the next iteration of this project, but haven't been able to find exactly what I'm looking for yet. If I was going to do this all over again, I would probably find "normally open" (NO) valves, as opposed to the "normally closed" (NC) ones I use here. When other people use the sink, they will forget about the pedal or don't like using it. If I'd used NO valves, the faucet would operate normally until the valves were energized, and the logic of the pedal would be reversed (pressing down on the pedal would break the circuit, causing the valves to re-open). If you're only designing for yourself, then you can have it behave however you like, but if there are others that are going to be using it, you might want to be able to switch it to normal faucet operation (you can accomplish that with my design, but it involves keeping the valves always energized, which seems like a big waste of electricity).
Also, with respect to neiljackson1984's idea about fixed amount of water, I wonder if the automated soda fountain mechanisms used behind the counter at fast food restaurants would be useful. Many of the worker-used fountains have buttons for fixed volumes (eg. fill this size cup). It may simply be those dispensers have good consistent flow rates and simply need programmed timings in an Arduino.
and great work with the solenoid....
im just thinking if i replace the solenoid with something...like a stopper from a **********...it might just work......but think i will leak out......as soon as i solved it i will post my solution.......
but for now...try to think what is ***************.......its from some where in your basement or in my house its in the kitchen....try to find out....
I really like the idea of fixed volumes of water being delivered. A tap of a hot or cold could deliver 1 cup. You could just time it if you can't get the flow-meter. 2 taps give 2 cups, 3 taps gives 4 cups.
wish i knew more about plumbing...
anyone know a good book or site?
Carolyn, and other sneak peeks from the Pratt Show on May 12-15th, can be found on our blog, Pratt Success! http://prattsuccess.blogspot.com
Sorry you didn't find this useful :) I didn't find any Instructables about it, but there are some good articles around about solar powered well pumps, maybe you'd get some use out of something like that?
http://en.wikipedia.org/wiki/Solar_cell
Even the article you link to admits the only advantageous use of solar electric is when, (and I quote) "remote applications where a solar-powered water pump is more cost effective than installing a conventional grid-connected AC pump."
We're talking miles of cable here to hit the break even point.
Solar electric makes absolutely no sense at all anywhere where electrical grid connection is feasible. Well not unless you are worried about the imminent collapse of society and really need that morning cup of Joe to get going.
Use tools, don't be one.
