3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Save Water! Kitchen Faucet with Foot Pedal
Step 6Install the Solenoids
The first step, and you're probably not going to like it, is to clean out the area under your sink. It's not fun, but it'll make life a lot easier.
Ok, now that we have that bit of unpleasantness dealt with, we need to find the shut-off valves for the faucet. These should look a bit like the third picture below. Turn these off, and verify by turning on the faucet (test both hot and cold!). Once they're turned off, position your bowl under one of them and disconnect the hose running from the faucet to the valve. Shake out any remaining water, and repeat for the other side. Make sure you keep track of which hose was connected to which valve. If they're not already labeled, a bit of masking tape and a pen could save you some heartache down the road.
Take your first solenoid assembly, and attach it to the valve and the corresponding hose. It's ok to coil your hoses, as long as the coil isn't too tight. I started by attaching the assembly to the hose running to the faucet, and then once that was secure, I attached it to the valve. Make sure you don't kink the hose as you tighten it. Repeat for the second valve. I made sure to position my solenoids "upright", so that if there were any leaks, they wouldn't come into contact with my electrical connections.
Turn on each of the shut-off valves and make sure you don't have any leaks. Water will only be flowing from the shut-off valve to the solenoid right now, so that's the area to focus on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:pjamestx
