3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Save a Broken Binding
It always bothers me when the binding on a good paperback reference book is broken. It happened to these two books when I lent them to people. I want to keep and use the books for a while without them falling apart, yet. You can see the white line marking the break in the binding on each. The top book has already received the repair this Instructable will describe.
Step 1Check the center margins
The plan is to stitch the book together with thin wire. Check the center margins to see how much room is available.
17 comments
May 19, 2011. 7:25 AMjtrent says:
i've tried to rebind books by hand before, bit of a mission to be honest. You have to have a steady hand a good eye for detail (which i don't) more recently i've just used book binders.
Dec 18, 2009. 7:08 PMframistan says:
I did this to a book once. I didn't use wire... i used a very strong upholstery thread... but any strong string would probably work.  then i filled the holes with glue... it was a book that our family all liked a lot and i saved it.
Sep 21, 2009. 8:25 AMthreadbare says:
I did it, I used this to fix a really worn out Indian cook book that I love and use all the time! I never would have thought of this and it worked great. Thanks!
Sep 16, 2009. 3:17 PMb1russell says:
How fabulous - I live in Phoenix, where leaving a book in the car - even briefly - means the glue is destroyed and pages fall out all over the place! Thanks for a really fast and easy fix.
Sep 12, 2009. 9:30 PMthreadbare says:
(removed by author or community request)
Mar 28, 2009. 6:41 PMrimar2000 says:
Phil, perhaps you know, but someone said "there are two kinds of fools: 1) those who lend books, 2) those that returns them" I write my daily personal journal, and I bind it in a similar way as you do. But my method is more "quick and dirty" as yours. Once a year (december) I generate the blank daily pages, one page per week, which usually makes 27 sheets printed on both side. Then I pick out some family photos for the covers and backcover, I stack and match the sheets and covers, I do with a sharp knife cuts 3 or 4 mm deep at the edge of the spine, about an inch away from each other. Then I insert a sewing thread in zigzag through the cuts and back. Once done, I cover everything with plenty of vinyl glue, trying to it penetrate the cuts so that the threads remain trapped.
Aug 5, 2009. 12:51 AMthreadbare says:
rimar2000, you should do an instructable and show how you make it. I love my journal and am always interested in how others make and keep theirs.
Aug 5, 2009. 4:51 AMrimar2000 says:
OK, I will do the instructable the next time I make my personal journal (next december). Anyway, It's easy to understand it by reading my above explanations, overcoming the difficulties of my English. 1) I create a OpenOffice Text Document whit all the weeks of the year, a week by page. 2) I print it in double face. As my printer don't do this automatically, I print first the odd pages, then the others. 3) I print in thick paper some family photos. I varnish them for more durability. 4) I stack all. I control the correct order. 5) I do with a sharp knife cuts 3 or 4 mm deep at the edge of the spine, about an inch away from each other. 6) I insert a sewing thread in zigzag through the cuts and back, several times for maximum strength 7) I cover the spine with plenty of vinyl glue, trying to it penetrate the cuts so that the threads remain trapped. 8) I cover the spine with a strip of paper to make it prolix.
Aug 5, 2009. 12:55 AMthreadbare says:
This is a great instructable. We have had two halves of a dictionary for almost five years! It's nice because two people can look up two different words at the same time, as long as they aren't in the same half of the dictionary. I will be using this great idea.
Mar 28, 2009. 6:19 PMgraywave says:
I just use clear packing tape. If it is applied carefully usually it can't even be seen.
Mar 28, 2009. 12:24 PMdchall8 says:
Good idea. You can get more of that stainless wire in either the sporting goods department (fishing line) or the hobby department (beading) of your local wally's. The cost is the same either place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
