loading
Step 7: UPSIDE AND INSIDE OF CDs - LADOS DE ADENTRO Y AFUERA DE LOS CDs
You should be able to identify the Outside and Inside of your CDs or DVDs, and the Outside should be the side in which you
glued the bigger washer over the smaller washer, and the inside should be where you see the smaller washer.
IT IS VERY IMPORTANT THAT YOU IDENTIFY THIS ALIGNEMENT
Usted debe de ser capaz de identificar los lados de afuera y adentro del CD o DVD, el lado de afuera es el lado en que usted pegó la arandela grande sobre la pequeña, y el lado de adentro es adonde usted ve la arandela pequeña.
ES MUY IMPORTANTE QUE USTED IDENTIFIQUE ESTA ALINEACION
<p>I like it!</p><p> I am thinking of mounting this to a computer fans motor to generate Electric for a USB device.</p>
Hi Slim, I am having trouble with my browser to the point that when I try to reply your last message it sends me to reply to your first message. Please write to me directly to mi mail <br> <br>mundodigitalnic@gmail.com <br> <br>I will anwser. <br> <br>But trying to answer what I understood from your mail is that the computer fan got hot when you blew it with a dryer. <br> <br>I have some questions <br> <br>did you blow the computer fan directly with the dryer? <br>Was the dryer HOT? <br>Did you modified the computer fan so that it could generate energy? <br> <br>Write to me and we talk about <br>thank you <br> <br>Carlos Arguello
Thanks for the reply!<br> NO , my dryer has a cold setting, just seems the body/hub was hot.<br>may be normal, for all I know.<br>I did no modification, just reading the out leads. of a straight out the box CPU fan. hte pix I sent was of a diff attempt, wiht a fan that was out of order, tried to start from scratch.<br>Steve
<p>To get the CPU fans to generate energy you must modify them, here I have a link in Portuguese but there are a lot of indications on how to do it in English</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/d6bd98bFpAQ" width="500"></iframe></p><p>ope you enjoy this. By the way you can use one of these Fans to generate energy with the SAVONIUS as the propeller and torque</p><p>Carlos Arguello</p>
Hi Slim49, <br> <br>Thank for liking my Project and hope you &aacute;re able to mount on it a fan motor to generate energy. <br> <br>If you use a Computer Fan and modify it you can generate between 7 and 12 volts, it will depend on the wind speed you get. <br> <br>If you do your savoniuos a Little larger tan I did you should get more torque on it. <br> <br>Let me know when you finish your Project <br> <br>Thank you <br> <br>Carlos Arguello
Hello,<br> thank you for your interest.<br>I tried to use a CPU fan with a hair Dryer test blower. only got a volt &amp; 1/2 dc out of that! :-( and the fans body got really hot<br>see pic, I then took an old fan apart &amp; dremel ground off all the circuit traces to expose the 4 post on each comunators. tried various connections to get some output, Got ZERO_ ZIP, nada.<br><br> any ideas?<br>Slim
Please visit my other INSTRUCTABLE on WIRING THE COIL
THANKS CARLOS, GREAT JOB. I LOOK FORWARDS TO SEEING MORE. <br>MUDDy
I am working on it MUDDy, let you know when I am
I am working on it MUDDy, let you know when I am finished
like that idea.
Should try to make one, it really works and is fun, I am plannung to use mine to power a small axial flux generator
COOL IDEA! I'DE USE 26 GAGE WIRE FOR 4 COILS AND FOUR, 1/2 INCH BY 1/8 INCH MAGNETS FOR EACH MAGNET ROTOR. I BET IT WILL SPIN NICELY. <br>MUDDy
About This Instructable
4,415views
3favorites
License:
More by Happy2Think:WIRING THE COILS IN 3 PHASES AXIAL FLUX GENERATORS Savonius make one from old CDs DVDs
Add instructable to:
