3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Scallop Your Guitar (Standard Scallop, Frets 14-21)
Hey again everybody.
I'm back, with another handy instructable if you're in the mood of cutting up your guitar even more.
This time I will explain how I scalloped my fretboard, and how you can too.
Scalloped fretboards are not very common these days, but have been around of hundreds of years (like the veena, an indian instrument with a mad crazy scalloped fretboard) Recently scalloped fretboards have been introduced to the world of electric guitars through plays such as Ritchie Blackmore of Deep Purple, and Yngwie Malmsteen. However, they both use full neck scalloped guitars, and this instructable is for a standard scallop, meaning frets 14-21 are scalloped.
So what exactly are scalloped frets? Scalloping a fretboard is when you remove wood from the fretboard so that when the guitar is played, the fingers only contact the string, not the wood underneath, eliminating massive amounts of friction. It is much easier to bend strings with a scalloped guitar, and many guitarists do claim that scalloped fretboards allow you to play faster, as minimal contact with the string is needed (though I have not experienced this, nor have other guitarists I have talked to).
DISCLAIMER: I am not responsible for any harm that may come to you or your guitar. You can scallop you guitar beautifully with absolutely no previous experience as a luthier. Minimal experience with wood is suggested (we've all taken shop one time in school).
Take you time and be patient.
You might want to do this on that old guitar sitting in your garage rather than your brand new guitar
Thank you to everybody who voted in the Art of Sound contest!
Step 1Materials
Materials
-A guitar
-Some duct tape, or masking tape
-A rounded metal file (meaning its round all around) Mine was about 5/16" in diameter at the widest section.
-Murphy Oil (any wood cleaner can do I think)
-A toothbrush
-Sandpaper of many variates of fine grit.
-Dremel with a buffing wheel attachment, or a buffing wheel of some sorts. (A rag can work too)
-Screwdriver
-Wire clippers
-New guitar strings
234 comments
1-40 of 234next »
May 20, 2012. 1:35 PMfreeza36 says:
What is the point of scalloping frets?
Jun 20, 2009. 4:55 PMntagn33 says:
Looks good. I did this once on a friends Jackson DInky. Except I just used a Dremel tool with those little drum sander bits for the whole job. That way you don't go across the grain. That got the job done in no time, and it came out clean enough that my friend was able to sell the guitar. I wonder how it's done at the factory.
Feb 20, 2012. 12:39 PMHazzard2theworld911 says:
they use what is basically a drum sander controlled by a computer, but very few factories make these features, as they are expensive and difficult on Mass Production....
Feb 20, 2012. 12:33 PMHazzard2theworld911 says:
man, you mangled those frets.... I did this, but I used a Drill press with a sanding drum, and it turned out wonderfully
Jan 15, 2012. 6:34 PMpowercow244 says:
this seems really cool and awesome but... sorry, I don't wan't to destroy my guitar ... it means a lot to me and if i messed up... i would be really sad.
Jan 11, 2012. 6:03 PMxntrick says:
very cool, i was going to have my superstrat scalloped by some guy on ebay but i may have to try this. I already have a YJM type of strat and the scalloped neck is such a treat to play, the more i play it the lighter my touch becomes.
Oct 30, 2011. 12:17 PMFrozenIce says:
HAHAH THATS SOO COOOL!!! :) do u think doing it to a clasical would be usefull or good?? and reply would be usefull :P :)
Oct 23, 2011. 11:46 AMtsvoboda says:
Do you think this could also be done with a bass?
Aug 9, 2011. 12:19 PMHTWTUSA says:
Been playin' for over ten years and never even seen, heard of or considered this option...
just did it to my Artcore AF85 an I gotta say, after a couple of days getting used to it, I can freaking SHRED riffs faster than ever, with crystal clarity... (went all the way down to the 4th fret).
Thank you so much for allowing me to take my playing to a whole other level!
I've printed this 'ible and taken it and my Ibanez to my axe-smith...he'll be doing the mod on my other rigs for me, and possibly offering it to his other clients.
5 stars...all the way...good job!
Aug 9, 2011. 6:32 PMHTWTUSA says:
BTW:
To finish mine out, I just re-sealed the rosewood with a nice wood conditioner, followed by two coats of Minwax ultra poly with a run of 1000 grit between and after. Then I rubbed the whole board down with some super hard beeswax before I restrung it....
Plays like a rocket...xD
Aug 9, 2011. 6:28 PMHTWTUSA says:
I'm actually a master carpenter, so the finish work was easy...I just never thought to mod my frets...*facesmack*...
But, seriously man, other than beating on my guitars every day for the past 10 years, nothing has ever improved my game as much as this did.
Thanks a bunch.
Jun 11, 2011. 6:59 AMBobMarleyFan says:
I wouldn't clip the strings, the change in tension could damage your guitar, instead, loosen them and take them off or at least take most of the strain off of them and then clip them, plus this prevents strings from flying every where
Jul 18, 2011. 8:51 AMasdfcrow says:
The change in tension will not damage the guitar, provided you aren't using 12's. Guitars are built from stronger stuff than that. However, it probably is a good idea to loosen them, I just unwrap mine.
Mar 18, 2011. 6:28 AMjpman says:
what do you mean when your fret board starts to bevel??
i have an ibanez S
i dont think it has that
Nov 21, 2010. 3:54 PMdodeca says:
I suggest going to you local kitchen collection or other cooking store and get a half round micro plane i have also seen them in high dollar tool catalogs but i got mine cheaper at K.c . only cut into the wood not out of the wood
Nov 10, 2010. 7:16 PMclassicrocker182 says:
You can eventually buff and use uber fine gritted sand paper and get the frets looking nicer but this 'mod' is for performance
Nov 6, 2010. 12:53 PMBFMV93 says:
how far should u file down to the fret?
Nov 6, 2010. 5:40 PMBFMV93 says:
Alright thanks man i appreciate it
Nov 6, 2010. 12:38 PMBFMV93 says:
ive been playing scalloped frets for about 4 years now and this instruction uve made has deffinetly helped to do it RIGHT lol. and i believe it does make you play faster. i play speed metal and thrash on a gibson explorer
Oct 27, 2010. 9:57 AM!revenge! says:
i've heard that if you remove the strings of a gibson guitar, the neck will bend because the tension is lost. so is it actually possible to do this on a gibson lp guitar?
Oct 27, 2010. 1:11 PM!revenge! says:
yes i know that, but if you want to scallope your guitar, you will have to remove the strings. because the tension is lost, the neck can bend.
Oct 28, 2010. 9:40 AM!revenge! says:
okay
Oct 19, 2010. 11:42 PMthe_burrito_master says:
Nice, I don't play guitar but for the short times that I've picked one up I've really seen the need for this. If i were to play I'd do this.
Oct 10, 2010. 3:18 PMPieMaster777 says:
by curved do you mean up and down? If so, then does it matter if it is curvy because the point of scalloping is to remove contact.
Jul 1, 2009. 1:25 PMBigMac96 says:
Would it be useful to scallop the frets on a bass?
Oct 5, 2010. 2:42 PMmoogbeatz99 says:
not really.....
Dec 24, 2009. 10:24 AMrocketkid says:
if you bend on it then, sure.... lol personally, ive never tried bending notes on a bass, but i mean, if u have enough muscle to pull that off, it would probably be badass...
Sep 23, 2010. 4:48 PMdfwsupergeek says:
It's not hard at all to bend notes on bass. I could never get the range of bend out of them, but bending is no problem. Especially on my Aria Pro Integra Bass, which I broke the truss rod on years ago. I wish there was an instructible on how to fix those...
Oh, well- life goes on!
Again, great job!
Jan 20, 2010. 5:17 PMClayton H. says:
Billy Sheans bass is half scaloped. and its not that hard to bend a bass string.
Apr 29, 2010. 1:41 PMcj72396 says:
 I do a lot of bending in my bass solos, and it's not hard in the slightest.
Sep 24, 2010. 8:21 PMpuzzledones says:
I had a Vox Guitar back around 1969 that had all the frets scalloped. Sold it at the time to buy my first Trumpet.
Oct 5, 2010. 11:41 AMpuzzledones says:
At the time I also had a Trainer Custom Reverb Amp with 4 10" Speakers. The problem with the Vox was that I couldn't get any power out of the amp with it. Do not remember my original guitar. But I got lots of sound out of the amp, so it must have been something in the Voxs' Pickups
Sep 26, 2010. 5:32 PMDark Solar says:
love that rubber-band model airplane layout background! classic!!! : D
oh, top-notch 'ible too.
1-40 of 234next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:itsachen
Student, guitarist, tinkerer I've always loved tools and working with my hands. Coupled with a DIY spirit and intrinsic frugality, I try to bring you something new with each instructable.
