Scanner Parts - Desk Lamp by jpitz31
This instructable shows you how to make a desk lamp out of scrounged scanner parts and a few extras from Home Depot.
I have set up a small solar array, controller and a storage battery. I wanted to make some low power lighting that I can use in my office that would not consume a lot of power.
I had a bunch of scanner parts lying around and decided to put them to good use.
Step 1: Get Your Parts
Scrounge a scanner head and pick up the following parts from Home Depot:
1. Scanner Head
2. 6' Lamp cord and switch - $3.99
3. Low voltage lighting base - 2 for $5.95
4. PVC 1" adapter threaded on one end, slip to fit on the other - $.87
5. 12" x 1" diameter PVC threaded pipe, (nipple) - $1.12
Tools needed:
1 1/4" hole saw
electric drill
knife
hack saw
hot glue gun
solder iron & solder
shrink tubing
12" ruler
side cutters
Remove the lens and camera electronics and save for your next project.
Keep the displayed power circuit in place on the scanner head.
Step 2: Trim the Low Voltage Base
Take your knife and trim the extruded ridges from the base plate.
Rotate the base and trim all the ridges.
Step 3: Remove Upper section from Base Plate
Take your hack saw and remove the displayed section from the base plate.
The 1" PVC adapter will not fit unless you remove this section.
Step 4: Attach PVC Adapter
Press the 1" PVC adapter (slip to fit side) onto the trimmed base plate.
Step 5: Attach and Trim PVC Pipe
Screw the PVC pipe into the threaded adapter and use your hack saw to trim the pipe:
I trimmed my pipe to 12" from the base plate. You can adjust yours to fit your needs.
Lower for brighter focused light, Higher for wider disfused light.
Step 6: Remove reflector side of Scanner Head
You will have to play this one by ear. I am sure that each scanner head is slightly different.
Remove the screws and carefully remove the base plate.
Be careful not to damage the light tubing when you remove the cover.
Notice the light tube reflectors that run along the slot for the light tube.
Step 7: Length Measurment
Measure the mid point on the base plate to properly align the hole you are going to drill.
Step 8: Measure center point for drill hole
Use the ruler to determine the center point on the base plate for both length and width so you mounting hole will be aligned properly.
Step 9: Drill your mounting hole
Center punch the location where your length and width measurements cross and drill your mounting hole.
You will need to drill an 1 1/4" hole in the base plate.
This hole is slightly under sized. You will need to file the hole slightly larger to fit the PVC pipe.
I used an old soldering iron to enlarge the hole.
Step 10: Install the Scanner Head
Insert the PVC pipe into the Scanner Head and hot glue the pipe in place.
After hot gluing, turn the lamp right side up and make sure that the scanner head is aligned.
It takes a minute for the hot glue to cool enough to become solid. This will give you plenty of time to align the scanner head.
Step 11: Trim the Power Circuit wires
We need to trim away the electrical connector in order to solder the lamp cord with the switch to the power supply leads.
Step 12: Solder the lamp Cord
Double twist the power leads on to the lamp cord and solder the leads.
Be sure that you run some heat shrink tubing onto the leads before you connect the leads.
After soldering slide the heat shrink tubing on to the bare sections of wire and heat with the soldering iron to secure the connections.
Step 13: Finish Up
In my application I will add some wire connectors and attach the light to my storage battery.
You may want to attach the lamp cord to an AC to DC adapter.
Notice the voltage and current readings on my power supply.
The lamp is running off of 12 volts and consuming 370ma of current.
The lamp could be just a bit brighter, for my taste, but it is enough light to read by.
I am thinking of adding a second light tube and power supply from another scanner head that I have.
Thanks
1-40 of 58Next »
mad hatter503 says: Jan 19, 2012. 4:07 PM
When connecting the switched power cord to the unit, it is a good idea to stagger the splices, one up towards the unit, one below that splice. Yes, it is only 12v, Yes, shrink tubing was used, but it is always to utilize some caution!
Thanks for sharing your idea!
jpitz31 (author) says: Jan 19, 2012. 7:07 PM
Thanks mad hatter503 for your tips. Looking forward to seeing some of your instructables.
Thanks
Joe
mcarugo1 says: Aug 20, 2011. 4:36 AM
I linked the inverter's wires with a ac cable from an old stereo, as I plugged in the inverter blowed up... where I did wrong?
jpitz31 (author) says: Aug 20, 2011. 10:28 AM
Hello,
Check the specs on the inverter. Most DC inverters Input DC voltage (low current) and then boost the output to run high voltage (around 2000 v) . By connecting AC to a DC inverter, you will get the results you experienced. ;-)
Always try to google the specs on any component before you connect power to it.
If you cannot find any specs then start with DC and proceed carefully.
Thanks
Joe
Ampix0 says: Dec 29, 2010. 8:45 AM
How would I run my bulb off batteries? I tried 2AA's and only like the first inch of the lamp barely lit up.
jpitz31 (author) says: Dec 29, 2010. 11:53 AM
Hello Ampix, You need at least 12 volts to run the light. Get yourself a small 12 volt lead acid rechargeable battery. I picked up a NP12-12T sealed battery at Frys Electronics.
Thanks
Joe
Ampix0 says: Dec 29, 2010. 2:25 PM
oh that is huge! XD I think im going to go with some simple LEDs for my project.
planetsideplayer14billion says: Feb 15, 2011. 5:19 AM
Thats what she said
w0rm5 says: Feb 10, 2010. 9:40 PM
Hi, I built one also, but didn´t used the scanner parts for the base, used an old lamp base I had. Works perfectly.
Great instructable.
livesteamfan says: Aug 6, 2009. 4:24 PM
Mine takes 12 volts in and it does work. But, just out of curiosity, how much voltage is going into the bulb? All I now is that it's enough to make a purple "spark" up to 1/4" in length and it hurt alot before I knew it could do that.
arduinoe says: Sep 21, 2009. 12:39 PM
its around 2.5KV (2500) volts , some can be as many as 10 KV
bronz says: Sep 2, 2009. 4:29 AM
These Two white wires how much current be given to them.As I use a adopter with these wires, there is already a circuit in front of you. So explain the amount of current be supplied to these white wires. Thanks.
Orbitalgun says: Jan 17, 2009. 5:35 AM
Thanks for this great instructable but please put more emphasis on the current and voltage drop when you mention lamp cord as it is a little misleading.
mike_d214 says: Dec 3, 2008. 3:00 PM
So I have a lamp, but it has 4 wires going in. Any ideas how to figure hook up?
ccg3 says: Jun 25, 2008. 2:35 PM
Excellent Idea. I always wondered if this could be done. Cool! Great Job!
crestind says: Jun 3, 2008. 2:30 PM
How long has your lamp lasted? I would imagine that this would burn out kind of quickly because the lamp wasn't designed for continuous use.
jgeekw says: Apr 30, 2008. 6:13 PM
I did this project and fried the PC board on the scanner head. I either swapped polarity on the wire, or there was too much power going to the scanner head. Any suggestions if I dont have the AC to DC converter?
jpitz31 (author) says: Apr 30, 2008. 8:50 PM
Hello Most converters take around 12 - 15 volts DC to run. Depends on what you used to power the board? Is there an input voltage written on the board? If you fried the board hopefully you have another one? Try to find a part number and manufacture name. Then you can attempt to look up the specs on their web site or give them a call. Thanks Joe
mikedoth says: Dec 2, 2007. 11:21 AM
What can I do if I can't find the wall converter?
jpitz31 (author) says: Dec 2, 2007. 5:21 PM
Do you have the inverter to power the fluorescent light? If so see below post. If not then you are going to have to find an inverter for your fluorescent light. If you have the inverter then you have to find out what the voltage and amperage rating of the inverter are. Then you can locate a wall wart rated for the inverter. Should be a common rating. Thanks Joe PItz
mikedoth says: Dec 2, 2007. 7:45 PM
I have the inverter that is attached to the black box that holds the light, I don't have the plug that goes from the wall to the scanner.
Aar000n3y says: Oct 18, 2007. 8:21 PM
My scanner is a bit different, and I couldn't figure it out. There were many wires coming from the main board to the light holder. But I couldn't find where it split to the light and the light detection part (not sure what it's called). So I took out the light, but I have no idea how it was powered. It looks pretty much like the light in the pictures. Is there any way to still use this or will I not be able to get it to work anymore?
jpitz31 (author) says: Oct 18, 2007. 8:55 PM
Hello Aar000n3y Look on your board and see if there is any power markings i.e. voltage in or power indications. If not, put the light back in the circuit. You are looking for wires that will power the board with around 12V. Look for a empty connector, This could be your voltage source to the board. If there is no connector then you will have two choices: Try to find the manufacture of the board. It should be written on the board, along with a part number. Send them an email and ask for the specs on the board. If all else fails then you will have to guess: Warning, You may toast the board in doing the below steps: Take a 12V source and see if you can find a pair of wires that will cause the light to light up. Do not touch the board when you apply 12V to it. Do not touch any bare wire, if possible insulate yourself by using insulated alligator clips. Briefly touch a pair of wires to see if the light works. If not switch the polarity of the wires and try again with the same wires. Then try each pair until the light works or not. Use extreme care if you do this last step. Do not touch any part of the light or circuit, Use insulated tools or power off the circuit, attach the alligator clips and them power up the circuit using your power supply switch. Do not touch anything with your bare hands. Thanks Joe
AzurusNova says: Sep 25, 2007. 2:35 PM
I have two moduals from laptop screens that gave the cathod tubes along with them. Now knowing that they are used in screens for laptops, the issue of UV should not be a problem. The only thing Im trying to figure out is what sort of power source is needed to power them. Id like to use one to light the inside of my desktop case and mod the second one to use as a lamp. Any information would be awesome. Ill post any results or make my first instructable of it as well. Thanks though for the little tidbits here.
jpitz31 (author) says: Sep 25, 2007. 11:15 PM
Hello, You need a dc inverter to drive the tube. You might have to do some digging on the web to find out the specs on the tubes and modules you have. I tore apart a bunch of scanners to dig up the inverters and tubes. Thanks Joe
AzurusNova says: Oct 18, 2007. 5:27 PM
True, its going to take some digging about. Well I think I might get lucky on powering my scanner lamp with the power out of an older style computer power system witht he extended power push switch. I havent learned what settings have to be on my voltimeter to see what the "ma" is on the 12v side, if you can direct me that way Im sure Id be right along with this build.
jpitz31 (author) says: Oct 18, 2007. 7:11 PM
Hey AzurusNova, Bre put out a very cool Make podcast that explains basic voltage, ohm and amp measurement using a multimeter. Check out this link. Also do some searching on the web for using a multimeter You should be able to find some good diagrams of proper usage. When you are measuring the inverter, be careful in not touching any components when the power is on. These inverters can cause burns to your skin referred to a "electrocautery" Thanks Joe
jpitz31 (author) says: Oct 18, 2007. 7:12 PM
AzurusNova says: Oct 18, 2007. 8:41 PM
Thank you much for the link. Once I get a chance after work to view over this video, I'm sure Ill know how to use it. Heh, Ill have an arm load of goodies coming home from work as well. Four older printers and 3 or more dvd players. All free because co workers have them laying about. I'm going to scrap parts out of the three printers and try to get one working. Not to mention its pay day and I'm finally getting my 19 inch lcd screen with built in speakers, DVI and VGA port.
lemonie says: Feb 11, 2007. 12:33 PM
These bulbs are not designed for room lighting, they may emit more UV than other desk lamps.
Steamdnt says: Oct 12, 2007. 3:52 PM
perfect for growing plants
jpitz31 (author) says: Oct 12, 2007. 3:59 PM
I never gave it a thought, but yes that would be a cool indoor plant lamp. Thanks Joe
jpitz31 (author) says: Feb 11, 2007. 3:48 PM
From the searching I have done on the web, scanner tubes give off low levels of UV radiation. This is a security prevention as many secure documents, money and checks have UV sensitive ink and a scanner will not pick up these UV sensitive markings. Though I cannot find any UV wavelength information by searching on the web to indicate what degree of UV the tubes do emit.
lemonie says: Feb 18, 2007. 3:48 PM
I saw a news article which reported a kid getting 'welder's eye' from a photocopier. Correct or otherwise, it gave me the thought. Thanks for the check & update. L
gfixler says: Mar 9, 2007. 2:39 AM
I'm sure it all depends on the bulb, and maybe even the kid, but being a weirdo artist/maker boy back in the 80s, with a stepdad who had an office scanner - a big old Xerox - I used to make photocopies of my face all the time. In art college, when bored working in the writing studio, I would make scans of my face, rolling with the scan to unwrap my face, or with it to compress it, or in spirals to create crazy warps. In almost all of my scans, I kept my eyes open, and looked past the bulb as it passed my face. Everyone always panicked, asking "You looked at the light!? You could go blind!" I always replied "Why do you say that? It's just a light bulb, and not all that bright, either." Then I'd always hear "Well, I just heard they're dangerous, like X-rays." "What? Where did hear that?" "I don't remember.' Literally, every conversation about my face scans went that way. No one could ever remember, or find again where they heard something that seemed benign to me was actually dangerous. Now at 30 years old, I'm the only one of my handful of friends from art school who still doesn't need glasses. In fact, I still have better than 20/20 vision, no color deficiencies, no near/far-sightedness, and I can control my eyes separately, which is very helpful with the kinds of stereographic imagery with which I like to code and play. I also spent the bulk of my childhood reading in very poor lighting, or in near darkness. We lived in the woods, away from the city, so it got pitch black when we turned all the lights off at night. I would often read for a while by the light of the green numbers on the VCR across the room from me - my only late-night light source. If I unplugged the VCR, it was absolute darkness. My eyes would never adjust. I kind of miss that, as my apartments since are impossible to get completely dark. However, my mother would yell "How can you see anything!? Turn on a light! You're going to hurt your eyes!" To that, I always responded with "How can darkness hurt my eyes? Light is radiation. You can be blinded, set on fire, or killed by radiation, but no one's ever been hurt by darkness itself." I guess I was kind of an pain, but from a very early age I had an incredible skepticism, and a tremendous thirst for the real reasons behind things. Of course, all that said, I don't think my shenanigans have had anything to do with my eyesight being as good as it is, and I'm quite thankful, and feel quite lucky that it is so, especially given that my parents have all sorts of eye issues, with both needing weird, strong prescriptions (mom's like 20/70 in one eye, 20/200 in the other), but a lifetime of warnings about what would hurt me, the great majority of which never panned out have made me only more cynical. I could've used a warning about NOT pulling wood through a table circular saw from that back side though. Thankfully that healed up nicely :)
davidlaska says: Jul 10, 2007. 4:50 PM
Normal or perfect vision is a recessive trait, far sightedness is a dominate trait similar to dark is dominate over lighter skin. No one gets out alive without suffering loss of vision and needing corrective lenses. If nothing else, the cornea (the lens that changes shape to focus, cameras change the distance) simply hardens over time. My favorite scanner light was from an early UMAX, they used regular size florescent lights. The ones that a are twice as long as the ones in the Colmen lanterns. This UMAX light was a very bright pleasant green light. I put this bulb in a regular florescent fixture that took the same size bulb (f-8)?. This green bulb is much brighter than the white bulb.
lemonie says: Mar 9, 2007. 3:06 PM
I don't wear glasses/contacts either. Opticians have an an interest in selling you these (esp. if they're offering 'free' eye-tests) Or am I just being syinical?
steven07 says: Jun 3, 2007. 5:59 AM
THANKS
For the free lamp
now back to making the UV light box
peterrabid9 says: Jan 30, 2007. 11:51 PM
I'm new at this so I don't understand something... Isn't a power adapter required to bring the voltage down to an acceptable level for the little circuit board? I would assume these things consume a very small amount of voltage. Does the board pass back anything that's not needed for the light to operate? Thanks, this is a question that's been bothering me.
trebuchet03 says: Jan 31, 2007. 12:33 AM
In the main picture -- do you see that box in the background that says 12 in green numbers and .37 in red? That' the power supply he's using to test ;) 12V consuming .37A His board looks almost identical to mine -- just put in the supply voltage and it outputs the appropriate voltage for the bulb (several thousand volts) ;)
1-40 of 58Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
