3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Scanner Parts - Desk Lamp
  • last photo ←
This instructable shows you how to make a desk lamp out of scrounged scanner parts and a few extras from Home Depot.
I have set up a small solar array, controller and a storage battery. I wanted to make some low power lighting that I can use in my office that would not consume a lot of power.
I had a bunch of scanner parts lying around and decided to put them to good use.
Step 1Get Your Parts
Get Your Parts
Scrounge a scanner head and pick up the following parts from Home Depot:
1. Scanner Head
2. 6' Lamp cord and switch - $3.99
3. Low voltage lighting base - 2 for $5.95
4. PVC 1" adapter threaded on one end, slip to fit on the other - $.87
5. 12" x 1" diameter PVC threaded pipe, (nipple) - $1.12
Tools needed:
1 1/4" hole saw
electric drill
knife
hack saw
hot glue gun
solder iron & solder
shrink tubing
12" ruler
side cutters
Remove the lens and camera electronics and save for your next project.
Keep the displayed power circuit in place on the scanner head.
58 comments
1-40 of 58next »
Jan 19, 2012. 4:07 PMmad hatter503 says:
When connecting the switched power cord to the unit, it is a good idea to stagger the splices, one up towards the unit, one below that splice. Yes, it is only 12v, Yes, shrink tubing was used, but it is always to utilize some caution!
Thanks for sharing your idea!
Aug 20, 2011. 4:36 AMmcarugo1 says:
I linked the inverter's wires with a ac cable from an old stereo, as I plugged in the inverter blowed up... where I did wrong?
Dec 29, 2010. 8:45 AMAmpix0 says:
How would I run my bulb off batteries? I tried 2AA's and only like the first inch of the lamp barely lit up.
Dec 29, 2010. 2:25 PMAmpix0 says:
oh that is huge! XD I think im going to go with some simple LEDs for my project.
Feb 15, 2011. 5:19 AMplanetsideplayer14billion says:
Thats what she said
Feb 10, 2010. 9:40 PMw0rm5 says:
Hi, I built one also, but didn´t used the scanner parts for the base, used an old lamp base I had. Works perfectly.
Great instructable.
Aug 6, 2009. 4:24 PMlivesteamfan says:
Mine takes 12 volts in and it does work. But, just out of curiosity, how much voltage is going into the bulb? All I now is that it's enough to make a purple "spark" up to 1/4" in length and it hurt alot before I knew it could do that.
Sep 21, 2009. 12:39 PMarduinoe says:
its around 2.5KV (2500) volts , some can be as many as 10 KV
Sep 2, 2009. 4:29 AMbronz says:
These Two white wires how much current be given to them.As I use a adopter with these wires, there is already a circuit in front of you. So explain the amount of current be supplied to these white wires. Thanks.
Jan 17, 2009. 5:35 AMOrbitalgun says:
Thanks for this great instructable but please put more emphasis on the current and voltage drop when you mention lamp cord as it is a little misleading.
Dec 3, 2008. 3:00 PMmike_d214 says:
So I have a lamp, but it has 4 wires going in. Any ideas how to figure hook up?
Jun 25, 2008. 2:35 PMccg3 says:
Excellent Idea. I always wondered if this could be done. Cool! Great Job!
Jun 3, 2008. 2:30 PMcrestind says:
How long has your lamp lasted? I would imagine that this would burn out kind of quickly because the lamp wasn't designed for continuous use.
Apr 30, 2008. 6:13 PMjgeekw says:
I did this project and fried the PC board on the scanner head. I either swapped polarity on the wire, or there was too much power going to the scanner head. Any suggestions if I dont have the AC to DC converter?
Dec 2, 2007. 11:21 AMmikedoth says:
What can I do if I can't find the wall converter?
Dec 2, 2007. 7:45 PMmikedoth says:
I have the inverter that is attached to the black box that holds the light, I don't have the plug that goes from the wall to the scanner.
Oct 18, 2007. 8:21 PMAar000n3y says:
My scanner is a bit different, and I couldn't figure it out. There were many wires coming from the main board to the light holder. But I couldn't find where it split to the light and the light detection part (not sure what it's called). So I took out the light, but I have no idea how it was powered. It looks pretty much like the light in the pictures. Is there any way to still use this or will I not be able to get it to work anymore?
Sep 25, 2007. 2:35 PMAzurusNova says:
I have two moduals from laptop screens that gave the cathod tubes along with them. Now knowing that they are used in screens for laptops, the issue of UV should not be a problem. The only thing Im trying to figure out is what sort of power source is needed to power them. Id like to use one to light the inside of my desktop case and mod the second one to use as a lamp. Any information would be awesome. Ill post any results or make my first instructable of it as well. Thanks though for the little tidbits here.
Oct 18, 2007. 5:27 PMAzurusNova says:
True, its going to take some digging about. Well I think I might get lucky on powering my scanner lamp with the power out of an older style computer power system witht he extended power push switch. I havent learned what settings have to be on my voltimeter to see what the "ma" is on the 12v side, if you can direct me that way Im sure Id be right along with this build.
Oct 18, 2007. 8:41 PMAzurusNova says:
Thank you much for the link. Once I get a chance after work to view over this video, I'm sure Ill know how to use it. Heh, Ill have an arm load of goodies coming home from work as well. Four older printers and 3 or more dvd players. All free because co workers have them laying about. I'm going to scrap parts out of the three printers and try to get one working. Not to mention its pay day and I'm finally getting my 19 inch lcd screen with built in speakers, DVI and VGA port.
Feb 11, 2007. 12:33 PMlemonie says:
These bulbs are not designed for room lighting, they may emit more UV than other desk lamps.
Oct 12, 2007. 3:52 PMSteamdnt says:
perfect for growing plants
Feb 18, 2007. 3:48 PMlemonie says:
I saw a news article which reported a kid getting 'welder's eye' from a photocopier. Correct or otherwise, it gave me the thought. Thanks for the check & update. L
Mar 9, 2007. 2:39 AMgfixler says:
I'm sure it all depends on the bulb, and maybe even the kid, but being a weirdo artist/maker boy back in the 80s, with a stepdad who had an office scanner - a big old Xerox - I used to make photocopies of my face all the time. In art college, when bored working in the writing studio, I would make scans of my face, rolling with the scan to unwrap my face, or with it to compress it, or in spirals to create crazy warps. In almost all of my scans, I kept my eyes open, and looked past the bulb as it passed my face. Everyone always panicked, asking "You looked at the light!? You could go blind!" I always replied "Why do you say that? It's just a light bulb, and not all that bright, either." Then I'd always hear "Well, I just heard they're dangerous, like X-rays." "What? Where did hear that?" "I don't remember.' Literally, every conversation about my face scans went that way. No one could ever remember, or find again where they heard something that seemed benign to me was actually dangerous. Now at 30 years old, I'm the only one of my handful of friends from art school who still doesn't need glasses. In fact, I still have better than 20/20 vision, no color deficiencies, no near/far-sightedness, and I can control my eyes separately, which is very helpful with the kinds of stereographic imagery with which I like to code and play. I also spent the bulk of my childhood reading in very poor lighting, or in near darkness. We lived in the woods, away from the city, so it got pitch black when we turned all the lights off at night. I would often read for a while by the light of the green numbers on the VCR across the room from me - my only late-night light source. If I unplugged the VCR, it was absolute darkness. My eyes would never adjust. I kind of miss that, as my apartments since are impossible to get completely dark. However, my mother would yell "How can you see anything!? Turn on a light! You're going to hurt your eyes!" To that, I always responded with "How can darkness hurt my eyes? Light is radiation. You can be blinded, set on fire, or killed by radiation, but no one's ever been hurt by darkness itself." I guess I was kind of an pain, but from a very early age I had an incredible skepticism, and a tremendous thirst for the real reasons behind things. Of course, all that said, I don't think my shenanigans have had anything to do with my eyesight being as good as it is, and I'm quite thankful, and feel quite lucky that it is so, especially given that my parents have all sorts of eye issues, with both needing weird, strong prescriptions (mom's like 20/70 in one eye, 20/200 in the other), but a lifetime of warnings about what would hurt me, the great majority of which never panned out have made me only more cynical. I could've used a warning about NOT pulling wood through a table circular saw from that back side though. Thankfully that healed up nicely :)
Jul 10, 2007. 4:50 PMdavidlaska says:
Normal or perfect vision is a recessive trait, far sightedness is a dominate trait similar to dark is dominate over lighter skin. No one gets out alive without suffering loss of vision and needing corrective lenses. If nothing else, the cornea (the lens that changes shape to focus, cameras change the distance) simply hardens over time. My favorite scanner light was from an early UMAX, they used regular size florescent lights. The ones that a are twice as long as the ones in the Colmen lanterns. This UMAX light was a very bright pleasant green light. I put this bulb in a regular florescent fixture that took the same size bulb (f-8)?. This green bulb is much brighter than the white bulb.
Mar 9, 2007. 3:06 PMlemonie says:
I don't wear glasses/contacts either. Opticians have an an interest in selling you these (esp. if they're offering 'free' eye-tests) Or am I just being syinical?
Jun 3, 2007. 5:59 AMsteven07 says:
THANKS
For the free lamp
now back to making the UV light box
Jan 30, 2007. 11:51 PMpeterrabid9 says:
I'm new at this so I don't understand something... Isn't a power adapter required to bring the voltage down to an acceptable level for the little circuit board? I would assume these things consume a very small amount of voltage. Does the board pass back anything that's not needed for the light to operate? Thanks, this is a question that's been bothering me.
Jan 31, 2007. 12:33 AMtrebuchet03 says:
In the main picture -- do you see that box in the background that says 12 in green numbers and .37 in red? That' the power supply he's using to test ;) 12V consuming .37A His board looks almost identical to mine -- just put in the supply voltage and it outputs the appropriate voltage for the bulb (several thousand volts) ;)
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:jpitz31(Joe Pitz Technology Blog)
Software Developer, like to work with electronics, embedded systems, robots etc.
