3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Schnibble Quilt - quick, easy & two-sided
I grew up in Pennsylvania Dutch country. My mom spoke "Dutch" to her brothers and sisters and lots of Dutch words and phases were used when they spoke English to us kids. ( In case you don't know about Pennsylvania Dutch - it is really a German dialect and not Dutch at all!) Schnibble (pronounced shnibble - rhymes with kibble) means a little bit of something - so it could be little bits of fabric for this quilt or little bits of paper when you cut out something or little bits of yarn or... almost anything else. The German dictionary lists the word schnippelche as a noun meaning snip, but growing up we always pronounced it schnibble...so I'm using my version.
This quilt is based on string pieced quilts, but I use the construction of each block for the "quilting." As you sew on the schnibbles, you are quilting each block. You then sew all the quilted blocks together to make a full size reversable quilt. I have attached photos of 2 quilts. One is made up of 25 blue cotton  blocks and fits on my queen size bed, the second is 16 blocks and is a lap quilt made of  purple corduroy fabrics.
Step 1STEP 1 - START CUTTING
NEEDED:
25 squares of fabric - 18"  - BACK SQUARES
25 squares of batting - 18" - BATTING
SCHNIBBLES = strips of fabric - varying widths & lengths12 strips of fabric 3 1/2 " wide for binding at least 80" long.
Sewing machine
Scissors or rotary cutter
18" template of acrylic or cardboard (optional - you can carefully measure and cut squares by hand)
BACK SQUARES:  Cut out 25 squares of fabric for the back. I use 18" squares and end up with a finished quilt that is 78" x 78" which I use on a queen-size bed. Use fabrics that you like, because this quilt is reversable and you want both sides to look good. The squares can be all one fabric or you can use coordinating colors.
I use a rotary cutter and an acrylic template to cut out my squares. For the 18" square template, I went to the local glass cutter and had them cut a piece of acrylic - they smoothed the edges. It cost about $17. You could easily use a cardboard template and cut them by hand.
Cut BATTING:  Cut out 25 squares of batting at 18" to match the back squares. Any kind of batting that you like, I have used polyester and cotton...and have some bamboo waiting to go.
Lay one of the back sqares face down and lay one square of batting on top
SCHNIBBLES:  Rip or cut strips of fabric into various widths (I use strips from 1 1/2" to 3 1/2".) Use a lots of different colors & patterns. The weight of the fabric should be similar, Don't worry if the weights are slightly different. Cotton fabrics last longer then polyester, but if polyester is all you have you can certainly use it. I use whatever I have in the back room.
17 comments
Mar 19, 2012. 8:47 PMnellene1953 says:
This is a great quilt to use up your scraps. I have found over the years the BEST basting spray is 505.
Jan 26, 2012. 9:12 AMKathy186 says:
Wow, I just came across your quilt. Love it!! I'm just learning how to quilt. I like this method of quilting that reduces the bulk of the whole thing beause I only use a regular sewing machine. I'm going to set aside a container and label it "schnibbles" and start tossing my fabric strips in it. One day I will have enough to make this quilt! Thank you for the great instructions.
Sep 2, 2011. 2:42 PMeehle says:
Ooh, so fun! Going to start one of these tonight for my 1 year old granddaughter. Everyone who makes one should come back and post a photo of their finished quilt!
May 29, 2011. 1:32 PMoneoldlady says:
OH MY GOODNESS!!!!!just found this quilt and LOVE it!!! SORRY.....but I'm just too old fashion to have pleats, so I dug out some quilt basting spray I bought about 3 years ago and sprayed my batting with it and then "stuck" the back square to it. NO PLEATS!!!....and the needle did not stick or gum up. It seemed to make up twice as fast as my first attempt....which had about hundred "pleats". I looked on Clotilde.com and they still carry it. It is supposed to be enough for 3 Queen sized quilts and is around $15.00. I think I might have seen it at Joann's fabric too. Wonderful stuff!!! I see alot of people getting quilts made this way for Christmas since I've had to really downsize my sewing room and have a chest of drawers full of scraps.
Apr 23, 2011. 7:01 PMcellmaker says:
Love the idea, but you lost me in the explanation of the binding. Not understanding how the striped border was attached to the blocks on the back. I will be making a king size....
Apr 22, 2011. 9:21 PMcooi says:
WOW! The quilt backing is really a beautiful touch!
Apr 22, 2011. 8:47 PMbusysdizzy says:
I LOVE this idea!! I have made many scrappy string quilts and usually back them with flannel or fleece to avoid quilting something so heavy. This is a wonderful idea that cuts down on the one step in making a quilt that I try to avoid. Thankyou!
Apr 17, 2011. 9:49 AMbptakoma says:
Great idea --
In step 2, are you sewing the strips to each other, or directly on top of the batting? I guess it's on top of the batting, which is why you quilt as you go. Are there any tips to keep it aligned/keep the batting from puffing things out of place? Do you need a wider seam allowance than the traditional quilters 1/4 inch? Normal stitch length?
Apr 17, 2011. 12:56 PMaholst says:
Schnippelche sounds like a West Prussian dialect, I heard my grandma using it sometimes. So it might well be proper German, just from areas that aren't Germany anymore these days!
Lovely quilting, I should really get my sewing machine out of storage...
Apr 15, 2011. 8:44 PMsparracco1 says:
i am SO going to try this! thanks! ;-]
Apr 14, 2011. 11:16 AMBrittLiv says:
Hi, I'm German and have never heard of the word "schnippelche" here we call what you mean "Schnipsel" or "Schnippel" (e.g. in Berlin).
Great jop on your ible!
Apr 14, 2011. 1:47 PMabbyholverson says:
Beautiful! I love your technique of quilting as you go. It makes it so easy!
Apr 14, 2011. 11:47 AMcdawisconsin says:
Beautiful =)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:casburkhart
