loading
Protect your laptop screen with this easy-to-make cover. This is a really great use for all those company t-shirts that don't really fit.
Step 1: Materials
You will need:
- schwag t-shirt
- backing fabric, could be a patterned fabric or another schwag t-shirt
- iron-on fabric adhesive
- thread
- scissors
- fray-check, anti-fray liquid, or clear nailpolish
- sewing machine (could also be hand-sewn or have no sewing)
- pattern or paper for making the pattern
if you want to include the fabric leash you will need:
- ribbon
- alligator clips
Step 2: Iron Out Shapes
Wash the t-shirt and the backing fabric to prevent bleeding and other issues. Iron both the t-shirt and the backing fabric flat.
Cut out around the printed company logo leaving plenty of extra space. Also cut a large piece of the backing fabric and the fabric adhesive. Following the directions on the fabric adhesive, adhere the backing piece to the t-shirt logo.
Step 3: Cut and Sew
Create a pattern to fit over the keypad on your laptop. I used the foam padding that came with my laptop for measurement. Pin the pattern on your fabric, centering the company logo. Then cut around the pattern.
Using a fun stitch, sew a pattern border around the edge. This will help keep the fabric pieces together and be a bit more decorative. You can sew a border by hand, or skip the sewing altogether.
Trim the edges of the fabric so they look nice and straight. Then apply a bit of fray-check around the edges on both sides to keep the fabric from fraying.
The cover is now complete. The following step is for adding a leash.
Step 4: Create the Leash
Eric told me he often forgets to put the cover back on his laptop after he's done working at the kitchen table. The leash should solve this problem. I made the leash out of some old alligator clips and some ribbon.
Take apart the alligator clips. Thread the ribbon through one of the plastic protectors and tie to an alliator clip. Add some fray-check to the end of the ribbon and put the plastic protector back over the clip.
Measure out how much ribbon is needed to fit loosly around the laptop. Cut the ribbon to length. Then thread the loose end of the ribbon through the other plastic protector and tie to the other alligator clip. Apply fray-check to the end and put the plastic protector back over the clip.
Now you have a nifty leash for the screen protector!
Step 5: Other Materials
Other materials work just as well and are equally stylish.
Here's a swash of silk fabric, which didn't quite make it into being a tie, protecting a laptop.
i would think that people would make inst. tees with iron ons and do that
Nice job!! I would most rather keep the Instructables shirt, but I will see if I can print the Instructables image and robot and stuff onto a cloth, then I'll use that for my keyboard. Nice job!
Just did a whole Instructable of my own before realizing that Leah had already done one. Extra points to her for reusing a shirt in a novel way. Mine, on the other hands, aims for slickness points, what with my use of our fancy laser etcher/cutter:<br/><br/><a href="https://www.instructables.com/id/Laser-cut-Laptop-Screen-Protector/">https://www.instructables.com/id/Laser-cut-Laptop-Screen-Protector/</a><br/>
one came with my HP DV6400 Customized
oh my god, it's "THE MACBOOK!!!!" could you help me do the same thing you did?
Thanks for these instructions. This is an awesome idea. I didn't know that my keyboard was causing all the screen issues. Cool. I have just added this to the spreadshirt blog - <a rel="nofollow" href="http://blog.spreadshirt.com">http://blog.spreadshirt.com</a><br/>
Excellent work pal, keep the good work!!
Nice sewing machine.
I used a sheet of latex to cover my laptop in the workshop. I can see the keys, use the keyboard but keep dust out the crude off my keyboard. Then with a wipe its clean and protects when the lid is down. Leah, I would suggest two bands of elasticated ribbon for the leash. I would be afraid of accidentally closing the lid on one of those croc clips and killing the screen.
Very true - the alligator clips made a pretty poor leash. I ended up not even using the leash at all. Certainly elastic ribbon would make a really nice leash.
Nice instructable. Clear pictures. Nice Step by step. Well done. But what does it do?
My old Dell D600 had this trouble as well. I spend hours typing away... and all the oils from my skin (along with random food items, gross I know) would be tranferred to the keyboard. Once I closed the lid all that crud would be transferred to my screen. Not good! Now, after a brief trip in for repair Dell fitted longer 'stand-offs' to the screen to prevent it from coming into contact with the keyboard... but it was already marked. This cover prevents that nicely. If one side was a nice fine microfibre it could even be used as a screen wipe.
Some of the larger laptops, particularly MacBook Pros, tend to rub their keys against their screens when shoved in a bag. On my laptop, I have a series of very fine scratches right where the space bar touches the screen. This fabric help protect the screen.
Very interesting...<br/><br/><a rel="nofollow" href="http://whosorthopak.blogspot.com">http://whosorthopak.blogspot.com</a><br/>
What other laptops -- other than Macs - does this happen to? I used to work IT at a high school -- we got about 60 iBooks and within a few months, at least half had the keyboard etching. I originally thought it was due to heat because the imprint only showed up on machines that the teacher would close (rather than leaving it open on the desk). But I guess that makes sense if it's scratching :P
About This Instructable
26,541views
26favorites
License:
Bio: 'what aboot me?'
More by leahculver:Schwag Laptop Keypad Cover Little Bags Deliver Kittens
Add instructable to:
