Scooter conversion from child's bike
 by blacksteel42
Featured
I found a kids 16 inch bike in a dumpster, and thought it might make a good base for a adults sized scooter.
It was pretty cheap to make with most of the cost in bolts and paint.
Materials
1 child's 16 inch BMX bike
20mm plywood (800 x 160mm)
22.2mm steel tube
5 x 8mm bolts and nylock nuts
4 x 6mm bolts and nylock nuts
7 x panel washers
1 can undercoat spray paint
1 can topcoat spray paint
8 x 60mm wood screws
Brake cable inner and outer
Tools Used
Hacksaw
Saw
Rasp file
Metal file
Drill with 6 and 8mm bits
Grinder
Wire brush
Ring spanners
Step 1: Deconstruct the bike
Remove all the parts that are surplus to your requirements, and strip the bike down to the frame.
Put aside the following:
Wheels
Brake
Headset stem and handlebars
Forks, bearings etc
GofishRC007 says: Jul 22, 2012. 4:58 PM
Put a motor on and you have a go-ped!Good ible might build one myself.
Daftehh says: Mar 3, 2012. 1:05 PM
Hows the speed on this? any videos?
blacksteel42 (author) in reply to DaftehhMar 24, 2012. 6:37 PM
I use it to keep up with my kids (4,6, 8) on their bikes so it's OK.
Philisawesome says: Mar 22, 2012. 12:05 PM
This is an awesome idea, do the brakes still work?
blacksteel42 (author) in reply to PhilisawesomeMar 24, 2012. 6:35 PM
The brake works fine. You could prob mount a rear brake as well and run the cable under the deck, but the front only pulls up OK.
duckef says: Mar 5, 2012. 5:28 AM
I'm going to try and use an old skateboard deck to use for the stand plate to give my large feet space
paganwonder says: Feb 15, 2012. 7:15 PM
I had the same idea for my commute to work- thanks for sharing your build, helps my confidence for trying it myself!
duckef in reply to paganwonderMar 5, 2012. 5:27 AM
That's what I will be using it for and it looks simple enough to build.
mstyle183 says: Feb 15, 2012. 1:13 PM
i had something similar in mind for another project.. was debating betweeen a 16 inch bike or 20 inch bike.. 16 inch bike it is!! thanks for this.. now i need a welding machine.. some cutters saw etc lol
ilpug says: Feb 15, 2012. 11:48 AM
http://www.xootr.com/
I
t looks like that^
Great build!
rimar2000 says: Feb 12, 2012. 3:40 PM
Good recycling work.
I think the union of the front deck is a little weak. Maybe you can to weld a bigger foot to join it with more screws to the platform.
Kiteman in reply to rimar2000Feb 13, 2012. 1:02 PM
I think (for a non-welded project) a wider plate underneath the deck (as mentioned in step 5) would be good.
To my eye, that particular joint looks as though it would flex and provide a certain amount of suspension.
blacksteel42 (author) in reply to rimar2000Feb 12, 2012. 5:28 PM
I'd love to if I had the welding skills. I must get to a class on it. Cheers.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
