Scooter conversion from child's bike
 by blacksteel42
Featured
I found a kids 16 inch bike in a dumpster, and thought it might make a good base for a adults sized scooter.
It was pretty cheap to make with most of the cost in bolts and paint.
Materials
1 child's 16 inch BMX bike
20mm plywood (800 x 160mm)
22.2mm steel tube
5 x 8mm bolts and nylock nuts
4 x 6mm bolts and nylock nuts
7 x panel washers
1 can undercoat spray paint
1 can topcoat spray paint
8 x 60mm wood screws
Brake cable inner and outer
Tools Used
Hacksaw
Saw
Rasp file
Metal file
Drill with 6 and 8mm bits
Grinder
Wire brush
Ring spanners
Step 1: Deconstruct the bike
Remove all the parts that are surplus to your requirements, and strip the bike down to the frame.
Put aside the following:
Wheels
Brake
Headset stem and handlebars
Forks, bearings etc
Step 2: Saw the frame
The cuts are shown in the photo.
Hacksaw off the top tube and seat tube.
Cut through the bottom bracket. Make sure the bearing cups are out of the bottom bracket as these will be harder to saw through than the bracket itself. Clean up the parts for painting later.
Step 3: Make the deck
Make your deck long enough to get both feet on when riding. Remember a bit of room will be taken up by the frame.
Cut out a hole for the rear wheel. I made mine by using the chain stays as a guide.
I wanted the fit to be tight and ending up filing a groove out for the frame to sit in between the wheel and the deck.
Also cut out some supports to bolt the chain stays to.
Step 4: Assemble the rear deck
Glue and screw the rear wheel supports to the underside of the deck.
I used 4 x 60mm screws in each side. Counter sink the screws as you don't want them sticking up in the top of the deck.
Once the glue has dried, work out how you can bolt the chain stays onto the deck. Ensure you have good ground clearance
for the back wheel, but not too high to make scooting a major work out.
I ended up changing the position of the frame on the deck to give more ground clearance. The second photo shows how it was before modification.
Step 5: Front deck
I found a 60mm pipe that matched the internal diameter of the cut bottom bracket. I bolted this to the frame with 2 x 6mm bolts. I then bolted the tube to the deck with 3 x 8mm bolts. I put big panel washers on the underside of the deck but it would be better to use a plate to spread some of the load.
It would have been great to get a plate welded onto the down tube, and just bolted that on. This is one part of the build that needs improvement as there is some flexing in the deck.
This was improved later by screwing a aluminum support under the deck.
Step 6: Extend the handlebars
I found a 22.2mm pipe that fit snug into the forks, and a sleeve that would take the stem from the bike.  This is another situation where some welding skills would be valuable.
The handlebars can be set at whatever height is comfortable.
I sourced some old grips and remounted the brake after painting.  The brake cable has been extended.
This design works well enough, but I'm sure it can be improved. Good luck!
GofishRC007 says: Jul 22, 2012. 4:58 PM
Put a motor on and you have a go-ped!Good ible might build one myself.
Daftehh says: Mar 3, 2012. 1:05 PM
Hows the speed on this? any videos?
blacksteel42 (author) in reply to DaftehhMar 24, 2012. 6:37 PM
I use it to keep up with my kids (4,6, 8) on their bikes so it's OK.
Philisawesome says: Mar 22, 2012. 12:05 PM
This is an awesome idea, do the brakes still work?
blacksteel42 (author) in reply to PhilisawesomeMar 24, 2012. 6:35 PM
The brake works fine. You could prob mount a rear brake as well and run the cable under the deck, but the front only pulls up OK.
duckef says: Mar 5, 2012. 5:28 AM
I'm going to try and use an old skateboard deck to use for the stand plate to give my large feet space
paganwonder says: Feb 15, 2012. 7:15 PM
I had the same idea for my commute to work- thanks for sharing your build, helps my confidence for trying it myself!
duckef in reply to paganwonderMar 5, 2012. 5:27 AM
That's what I will be using it for and it looks simple enough to build.
mstyle183 says: Feb 15, 2012. 1:13 PM
i had something similar in mind for another project.. was debating betweeen a 16 inch bike or 20 inch bike.. 16 inch bike it is!! thanks for this.. now i need a welding machine.. some cutters saw etc lol
ilpug says: Feb 15, 2012. 11:48 AM
http://www.xootr.com/
I
t looks like that^
Great build!
rimar2000 says: Feb 12, 2012. 3:40 PM
Good recycling work.
I think the union of the front deck is a little weak. Maybe you can to weld a bigger foot to join it with more screws to the platform.
Kiteman in reply to rimar2000Feb 13, 2012. 1:02 PM
I think (for a non-welded project) a wider plate underneath the deck (as mentioned in step 5) would be good.
To my eye, that particular joint looks as though it would flex and provide a certain amount of suspension.
blacksteel42 (author) in reply to rimar2000Feb 12, 2012. 5:28 PM
I'd love to if I had the welding skills. I must get to a class on it. Cheers.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
