loading
Step 4: Assemble the Rear Deck
Glue and screw the rear wheel supports to the underside of the deck.
I used 4 x 60mm screws in each side. Counter sink the screws as you don't want them sticking up in the top of the deck.
Once the glue has dried, work out how you can bolt the chain stays onto the deck. Ensure you have good ground clearance
for the back wheel, but not too high to make scooting a major work out.
I ended up changing the position of the frame on the deck to give more ground clearance. The second photo shows how it was before modification.
I know this is an old 'ible, but i am doing the same thing, but with a pair of electric hub motors, 48v 1000 watt each, brushless, and hemp the suspension components from the 24 inch mtb
Cool. I found a bike the same way. Working on cutting the frame now
Put a motor on and you have a go-ped!Good ible might build one myself.
Hows the speed on this? any videos?
I use it to keep up with my kids (4,6, 8) on their bikes so it's OK.
This is an awesome idea, do the brakes still work?
The brake works fine. You could prob mount a rear brake as well and run the cable under the deck, but the front only pulls up OK.
I'm going to try and use an old skateboard deck to use for the stand plate to give my large feet space
I had the same idea for my commute to work- thanks for sharing your build, helps my confidence for trying it myself!
That's what I will be using it for and it looks simple enough to build.
i had something similar in mind for another project.. was debating betweeen a 16 inch bike or 20 inch bike.. 16 inch bike it is!! thanks for this.. now i need a welding machine.. some cutters saw etc lol<br>
<a href="http://www.xootr.com/" rel="nofollow">http://www.xootr.com/<br> <br> I</a>t looks like that^<br> <br> Great build!&nbsp;
Good recycling work. <br><br>I think the union of the front deck is a little weak. Maybe you can to weld a bigger foot to join it with more screws to the platform.
I think (for a non-welded project) a wider plate underneath the deck (as mentioned in step 5) would be good.<br><br>To my eye, that particular joint looks as though it would flex and provide a certain amount of suspension.
I'd love to if I had the welding skills. I must get to a class on it. Cheers.
About This Instructable
32,309views
153favorites
License:
More by blacksteel42:Scooter conversion from child's bike
Add instructable to:
