Scouting Patrol Box
5,833
71
Published
Introduction: Scouting Patrol Box
This sturdy box can hold everything that a 10 person scouting patrol needs for a campout. Space is divided to provide an area for a two burner stove, washing bowl, pots, pans, propane lantern, lighter,dish soap,and utensils.
The box is made from a single 8'x4' sheet of 1/2" plywood
Step 1: Parts List
Lumber
  • 1/2" ACX Exterior Plywood. 4' x 8' sheet
  • 3/4" x 3/4" Poplar - 123 linear inches
Hardware
  • Strap Hinges 4” - National N127-969 - 2 off
  • Hasp 3.25” Safety Hasp - National V30 N102-277 - 1 off
  • Handles Spring Flex Cabinet Handle Zinc - Penn-Elcom H7154Z - 2 off
  • Chain - 22”
  • T Nuts 8-32 Grainger 1XGH2 - 20 off
  • T Nuts 10-32 - Grainger 1XGH4 - 16 off
  • Machine Screws 8-32 x 0.5” - Grainger 2AB31 - 20 off
  • Round Head Screws 10-32 x 0.5” - Grainger 1ZE21 - 16 off
  • Slide Bolt Spring Snap 3 3/8” - Grainger 4GGJ3 - 1 off
  • Wood Screws 8 x 1" - about 35
  • Carriage bolts 1/4" x 1" - 2 off
  • Nyloc Nut - 2 off
  • Para Cord - 10"
Step 2: Tools & Equipment
  • Table Saw (or ask your lumber supplier to cut the lumber to size)
  • Router with 1/2" bit
  • Clamps - lots of them
  • Screwdriver
  • Electric Drill & various drill bits
Step 3: Cut Out the Pieces From the 8'x4' Sheet of 1/2" (12mm) Plywood
Cut out the pieces per the attached plan
Step 4: Cut the Corner Supports and Bottom Rails to Length
  • Cut the 3/4" poplar into 15.25" lengths - 4 required
  • Cut the 3/4" poplar into 30.75" lengths - 2 required
Step 5: Use the Router to Add the Necessary Dados
The following pieces all need dados, rebates or slots
  • Left Side
  • Right Side
  • Front
  • Rear
  • Divider 1
  • Divider 2
  • Divider 3
For the dados and rebates, set the bit height to half way into the plywood (about 6mm deep)
The slots are obviously cut all the way through.
To make it easy, I marked the wood to show where the slots were to be made. And then made a simple fence to guide the router. It would be easier to cut the rebates using a router table.
Note that the top, bottom and Divider 4 need no routing
Step 6: Left Side
Step 7: Right Side
Step 8: Rear`
Step 9: Front
Step 10: Divider 1
Step 11: Divider 2
Step 12: Divider 3
Step 13: Sand All Pieces
Step 14: Glue Pieces Together
Step 15: Add Corner Supports
  • Glue in corner supports
  • Screw in place from both directions
Step 16: Add Bottom Rails
  • Glue in place
  • Screw in place
Step 17: Add the Hardware
  • Hinges
  • Clasp
  • Handles
  • Tie on the Slide Bolt Spring Snap with the paracord
  • Add lid chain with carriage bolts to both lid and base
Step 18: Add Primer and a Finish Coat of Paint
    • Oil Contest
      Oil Contest
    • Game Life Contest
      Game Life Contest
    • Water Contest
      Water Contest
    3 Discussions
    i love it! i think i'll make one for my camping gear!
    I remember having one of these as a scout. We added some detachable legs so it could stand on its own and made the chain just long enough so the lid could swing down and be a usable surface for prep etc...
    I love the clever design to only use a single sheet of material. Nice work!
