Instead, use the rest of the tiles as push pins on a bulletin board. You can use them to make words when there's not enough stuff to keep up or you can even use them as some sort of hierarchy. The order of the letters is how important the message is. Or you can geek out even further and use the numbers on the tiles to assign value to pieces of paper.
Either way, this makes use of an old game and also make the push pins a lot easier to stick in and pull out.
Remove these ads by
Signing UpStep 1Waht you need
- Thumb tacks
- Glue. In this case Loctite Stik 'n' Seal
- Scrabble tiles
I chose this glue over a couple favorites of mine: hot glue and cyanoacrylate. I've tried hot glue with this before and after a while the tiles came off. As for cyanoacrylate, it's great stuff, but with the slight curve at the top I wanted to use more glue to wrap around the edges.
Also, HERE are some other cool ideas for projects using them.
However there are plenty of places on both Amazon and Ebay to find them a little more easily.
