That's a nice name, but a more descriptive one would be "Scrambled egg still in the shell". This is a simple egg trick my Sensei told me about; it's easy and fun and makes a tasty hard-boiled treat.
**UPDATE** I've done some research. The actual name in Japanese is �rD�gu � or MD�D�g_~T which means Yellow Boiled Egg. Pretty straight forward name. I guess Golden egg is just the poetic version. (Instructables apparently doesn't support non-roman characters, so the Japanese didn't show up.)
Step 1: Getting started
- a raw egg
- one leg cut from a pair of nylons
**EDIT** It's been suggested that what I'm really using here is one leg from a pair of stockings. This could very well be true, as I know literally nothing about nylons or stockings. If so, just replace each instance of "nylons" with "stockings", and go at it!
**EDIT #2** Apparently the type of stocking / tight / legging / nylon may play a larger role than I knew. The stockings I use have a relatively low level of stretch. If the material is too stretchy then it won't spin properly. Also, it took me 4 eggs before I finally got a Golden egg (before I figured out the flashlight check in Step 3), so hang in there if it doesn't work on the first try!
Step 3: Is it Golden yet?
Step 4: Boil and Bubble
Put the eggs in a pot of lukewarm water until they are just covered. Heat. Once the water reaches a rolling boil set a timer for 6 minutes. When the timer rings, turn off the heat and soak in cold water to stop the cooking (and keep your hands safe).
**EDIT #3** People have commented on something I forgot to mention, which is that hard-boiled Golden eggs are harder to peel than regular hard-boiled eggs. For whatever reason, the scrambled egg grabs to the shell a bit stronger than usual and can make for an ugly peeled egg. (My first four eggs were hideous. Tasty, but hideous.) To solve this problem, and produce the not-ugly egg you see in this instructable, I used the back of a spoon to gently break the shell into small pieces, and then peeled it while submerged in a pot of cold water. It helped alot.
Step 5: Now what?
- Just eat it. Hard-boiled Golden eggs taste good by themselves, but a little sprinkle of salt never goes amiss. Or you can chop them up and throw them over a salad for some delicious protein.
- Mix it into a batch of regular boiled eggs. Like the old English tradition of hiding a coin in the pudding, whoever gets the golden egg gets good luck for the week. If it's Easter eggs we're talking about, then the Golden egg can grant good luck for the whole year. This throws a whole new twist into the Easter egg hunt tradition.
- Put a raw scrambled egg back in the carton as a harmless prank. The next time someone goes to make a sunny-side up they'll get a scrambled surprise.
- Hollow it out. Traditionally when hollowing out eggs you must break up the yolk with a long needle before it can be blown out. Golden eggs already have scrambled yolks, so just poke two tiny holes and blow it all out.
Visit Our Store »
Go Pro Today »
Here is "Fuwa-toro", the patented version of this.
Soft, fluffy and creamy since there's no bubbles in the egg when scrambled and by perfecting the cooking time and temperature. Yum~!
Also, when blowing eggs, before making the holes put a piece of wrapping tape where you are going to drill the holes. easier to drill that way and less likely to crack.
Here is a great way to boil an egg without making it tough. Try it on regular eggs and then on "Golden Eggs".
Place several eggs in a sauce pan and cover with cold water an inch over the top of the eggs. Place on high heat and bring to a rolling boil. As soon as the eggs reach a boil, remove them from the heat and set them aside for 10 minutes covered.
After resting ten minutes, rinse the eggs in cold water for a few minutes. Peel, salt, enjoy! This method makes a perfect boiled egg every time! It's a bit egg-centric but it works! - RA
Hold them at around ~75ºC for 30 minutes and enjoy creamy, soft scrambled eggs straight from the shell!
-BLUEBLOBS2
nice instructible by the way!
I'll post my results... SOON! ;-D
