3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Scrap Wood Cutting Board
If you work in a wood shop then you probably have a bunch of scrap lying around from a bunch of different kinds of woods. My dad and I made a bunch of these cutting boards from all the scrap we had lying around and didn't have to cut into one new piece of lumber.
These boards are made from (left to right): cherry, paduk, walnut, curly maple, purple heart, maple, cherry, walnut, curly maple and then more cherry.
You can actually make some pretty awesome things from all that scrap you have lying around...check out Scrapile, a furniture company that I have long admired.
If you really want to go the extra mile, burn a silhouette of Elvis into the back of one and give it as a gift.
14 comments
Feb 27, 2012. 2:27 PMTheCritic says:
I would love it if you would make one of these for me. I will pay for it along with shipping. Looks Fantastic.
Oct 2, 2009. 10:59 AMAsbestos says:
This is so pretty, and it's really sad that no description is given on how it's made. It's probably really simple to you, so you figure it needs no instructions, but if that's so, give us even just a few lines! I'm guessing: You glue a bunch of wood together, hold it in a vise for a while, and then just sand it all down? An instructible, even a two-page one, would be wonderful, thanks!
Jan 31, 2011. 12:23 AMhogthrob says:
Hi Asbestos,
to build this you need a set of sash clamps and some glue. Glue the sides of all the pieces of wood together and clamp them in the sash clamps until they are dry. Then sand them and apply a sealer preferably a low VOC if you are going to chop food on it.
If you are going to use it as a chopping board it would be better to rotate all the pieces through 90 deg so that the surface you end up with is all end grain.
Jan 28, 2011. 11:57 AMglorybe says:
You can avoid sanding and planing nightmares by building the top upside down with the face on a very flat surface that will not stick to your glue. Run tape where glue might squeeze out and ruin the appearance on both sides of the joint lines. If you use wood stains do all staining and finishing before using the glue. That way the color of the wood touched by your glue will not be changed.
If you have nice wood to begin with you can go over the surface with the Scotch brand fiberglass cleaning pads and that will smooth the surface prior to any staining or painting. It does not leave sharp little splinters of steel wool hiding in the work waiting to change color and spoil your work. Old fashioned, yellow carpenters glue works nicely compared to many modern glues. For example some of the glues that are so strong these days leave all kinds of nasty stains as they seem to almost boil out of joints and removing those glues when dry is a wretched task.
May 1, 2009. 12:29 AMkrampus says:
I saw this type of woods on tv, that 2 brothers and a friend in NYC who run a lab jointing up the scrap wood that they collect from factory and trash. the project is really cool.if i not mistaken is on the program know as big ideals for small planet.
Oct 10, 2008. 9:45 AMamercust says:
I have an abondance of beautiful scrap wood i would like to sell to someone who could use it. Wood pieces from maple, cherry, oak, mahogany, birdseye maple, honduran, rosewood, walnut, and many others. size varies from 1"x1"x12" to 1 1/4"x3"x96" and different sizes in between. If interested please contact me at 770-775-6900
Mar 23, 2008. 1:10 PMMr. Rig It says:
Would love to see you add this to my new group.
Hope to see you there.
Home Repair, Refurbishment, and New Projects
Feb 10, 2008. 3:16 PMteeps says:
This is beautiful and inspiring but almost completely lacking in any kind of useful instructions. Please assume that the audience knows absolutely nothing about wood working if you want this to be useful.
Feb 11, 2008. 3:57 PMteeps says:
Ah, gotcha. Didn't even know there was a portion of the site like that. It looks like you answered some of my curiosity below but I sure wouldn't mind seeing more detailed instructions.... for example, do you just clamp these together one by one until the whole thing is done?
Nov 30, 2007. 11:52 PMthewoodcarver says:
Maybe just a bit more on planing and gluing the wood ......did you just use Elmer's yellow ? What finish? Very nice work !!!! My scrap ends up in the fireplace or as checker / backgammon boards
Nov 30, 2007. 8:36 PMT3h_Muffinator says:
That's pretty awesome... I wanna try making something a bit more elaborate from this process... I'm thinking thin sheets of wood laser cut and glued on top of each other to make something 3D - kind of like a 3D printer...
Nov 30, 2007. 3:03 PMGorillazMiko says:
oooh. cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
898
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
