Step 8Stain & varnish
The best way I found is fairly simple (mind you, please google this, there's plenty of tutorials on staining wood). Baiscally take a brush in your right hand (if righty) and a clean rag (which will be thrown away after) in your left hand.
Apply stain with a brush, after when ready to dip your brush again, use your rag to wipe down the stained wood following the grain of the wood. This makes for a great finish!
If you're not satisfied with the color, apply a second coat to make it darker ( I used 2 coats on mine).
Once done it's time to varnish. Varnishing is also fairly simple. just brush in on with a clean brush but don't wipe... do the whole surface and let dry. Once dry sand it down with a very fine grit sandpaper (I used 600 grit). Wash the surface of dust and apply another coat.
I decided to go with a high gloss finish so I applied quite a few coats of varnish (5 in total). sand down between every coat, the final coat can be brushed down with 0000 grade steel wool.
Voilà, une belle table neuve!
Thanks for the advice on using normal stain!
