Scrap Wood Coat/backpack Hanger
1,293
35
Posted
Introduction: Scrap Wood Coat/backpack Hanger
Quick and easy coat rack or backpack hanger
Step 1: Cut Lumber
Rip 2x4 cedar slightly off center down the length of the board
Step 2: Assembly
Lay out the wood in your desired pattern. lay a wavy line of wood glue between the bottom 2 pieces of wood and clamp together. Screw three 2 1/2 in. wood screws through each end and middle of the board (you may need more or less depending on the length). To prevent splitting you may want to predrill the holes before screwing together.
Once you have the bottom two pieces assembled, add the next pieces one by one by removing the clamps, adding glue and then screwing from the top followinging the above steps .
Step 3: Hooks
You can use just about anything for hooks (doorknobs, railroad spikes etc.). I used the legs off an old iron patio chair I had lying around. make sure to attach them securely and with proper glue or hardware
Step 4: Mounting
locate studs in your wall to screw into or use 75 lb drywall anchors. mount the rack by screwing directly through the middle row of wood.
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
2 Comments
Nice work!
