Scratch Built Delta Wing RC Plane
Published
Introduction: Scratch Built Delta Wing RC Plane
About: I am a teenager that loves creating and building to hopefully end up in an Aerospace engineering job someday in the future!
After being tired of using other peoples designs and PDFs. i decided to make my own! i came up with a base design and made up the body while creating the plane. i knew i wanted a stream lined  body to reduce drag on the plane so i came up with the long slender fuselage and a sleek compartment  for the components of the plane to sit in. Using a computer i came up with a basic out line for the plane. as you can see my base idea came alive in probably my favorite plane yet. the blue cards are note cards covering up logos and return address's(if i lose it somehow). i would like to buy a stunt camera to attach to the bottom to be able to get an Arial view to do some spying! (just kidding i wouldn't use it for creeping on people but it would be cool to have)
The plane measures out at a 31" wing span and 38' long
A step by step will be out but unsure of the date. Also the step by step will be of the plane i am currently building and planing which is more advanced and 3x bigger then the plane below!! there will also be a video of the plane below flying along with a video of the plane flying!!
Hope you enjoy!!
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    14 Discussions
    They made a copy of the Predator UAV a few years back. It had a gimbal mount with a camera in it. Spy planes have been done. Instead,put racks in it and use empty CO2 cyllinders as dummy bombs and make it a bomber!
    Depending on where you order and what parts you already have, i would probly say 70$-80$ without the transmitter and reciever.
    I found planes for the body of another plane i built at http://rcfoamfighters.com/blog/ If u go to their airplane page there are some free PDFs that you can download and cut out to make templates for the body of the plane. that's how i got started along with thousands of youtube tutorials. Good Luck!! there very fun to make and fly! ( the plane in the instrucatable is not on the website but i will be creating a step by step for this one)
    A step by step will probably be made in a month so hopefully it will help anyone in getting into the RC plane world!
    Nice design.
    Regarding "With a big enough response..." I said "a good teacher teaches his class even if only one student is present".
    Thank you and i said that because the plane does cost a decent amount of money to build, but speaking i am still a amateur at flying RC planes ill probably crash it then rebuild it. its then during that rebuild process i will make the step by step. Overall i will be posting a step by step. Also thank you for the advice!
