Scratch Made Robot Wheels
366
Posted in TechnologyRobots
Introduction: Scratch Made Robot Wheels
About: Maker | Open source ❤ | Engineer
Do you want to know inexpensive way to make wheel for your robot.So this instructable can really help you .
Here in this instructables i will explain, how to make a scratch made wheel for robot.
It is 100% Home Made
Step 1: Materials Used
  • PVC Pipe (PVC pipe is used as rim ,I used 1.5 inch PVC, you can use as per your requirements.)
  • Sandal (The rubber from sandal will be used as tire
  • Screws
  • Pen Tubes(To fix motors to wheel)
  • Hobby knife
Step 2: Marking on Sandals
  • First draw a circle with same diameter of the PVC Pipe.
  • Make a square around the circle and by joining diagonals you can find the middle point.
  • Next step is , by using a drawing compass draw a circle with more diameter than the PVC from the middle point, so the second circle will be used as tire.
Step 3: Cutting
By using a hobby knife cut it carefully
Step 4: Fix It
After cutting you can see as per previous step you will have 2 rubber pieces,so you can insert one piece inside the PVC and another one you can insert outside of PVC.
Note:
The both piece will be tight enough so no need to apply any gum or something
Step 5: Making Wheel Connector
In order to hold the motor we need to make a connector.I have made the connector using Pen tubes.
To make this....
  • Cut the tube of 2 cm length
  • By using a screw fix one end of tube to the middle of wheel .
  • To ensure that the motor's shaft will be tight enough ,make a hole on the side of the tube (perpendicular to the motor shaft) and insert a screw to tight it.
If you have any doubts please refer above images
Step 6: Done !
Happy Making everyone and see you in the next project :)
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Pocket-Sized Contest
