3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Screen Printing Machine: Print Faux-co!
Step 5Install hinges
Install hinges
(Skip reading this step if, unlike me, you are a confident woodworker)
Place your frame in position around the foam on the top block. Then, put the two blocks on top of each other, foam side in. Then hold the hinges up to the wood to see where you'll need to place the screws. There will be a small gap between the two blocks.
I found it helpful to mark the holes, make a small, centered hole with a nail, then pre-drill a hole for the screw. Precision is important here, so take your time and measure twice!
Finally, when you start screwin', put all the screws about 3/4 of the way in, check the alignment one last time, and then finish the job. Double check that the hinge is parallel with the block edge. (I'm warning you because I had to re-do it the first time).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lemmingsolution
