Screen Printing Machine: Print Faux-co!
Step 6Make your prints!
Make your prints!
Grab your completed frame. Add a small amount of screen printing ink to the top of the stencil (on the dull side), under the plastic piece. Be sure you have a piece of paper underneath as you do this, to catch any drips.
Attach the frame to the top wood block with tape, plastic side down (touching the wood).
Put a piece of paper on the bottom block. The foam surface is an easy way to gauge where your print will appear.
Close the top block, and press down.
To recap: at this point, the closed press "sandwich" from top to bottom would be:
1. The top wood block
2. The top piece of 3.75 x 4.75 foam attached to the wood block
3. The 4x5 piece of plastic taped to the frame
4. The screen/stencil taped to the frame
5. The cardboard frame to which the plastic and stencil are attached
6. The paper
7. The bottom piece of 4 x 5 foam
8. The bottom wood block.
Now open up. Your print is ready!
One caveat to this method: I notice that it presses more ink through the screen than the traditional squeegee method. The last picture shows the "textured" look that the Faux-co produces. I'm not sure if thinning the ink would correct this, or if there's another way to avoid it.
2 comments
Sep 3, 2008. 3:04 PMkretzlord says:
well, they use a screen to put the ink on the pad, at least that's what it looks like
Jan 25, 2008. 11:29 AMC-lo says:
I believe that is pad printing, not screen. Still ingenious
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lemmingsolution
