Buy this one at Etsy: Click here!
Remove these ads by
Signing UpStep 1Assemble Your Materials
2 6x6 blocks of wood (free scraps from your favorite lumberyard)
4x5 Stencil Pro or Photo EZ stencil (I got mine from Circuit Bridge)
(This is basically a "silk" screen with light-sensitive emulsion already attached. For this tutorial I'm assuming that you have this product and have already followed the instructions that come with it to expose the emulsion and create your stencil.)
The 4x5 sheet of stiff plastic backing that comes with the stencil.
2 sheets of sticky-backed Fun Foam
1 6x6 piece of sturdy cardboard
2 hinges and screws
ruler
drill (not pictured)
scissors
craft knife
screen printing ink
tape
glue (I used a glue dispensing thingy normally for scrapbooking)
Thank you for your details. After I read what was wrote there i was very curious about Print Gocco
the excess ink that comes through is most likely from there being ink left in (or behind in this case) the screen when it is pushed through, because after the ink being laid down pushes through, the ink still in the screen will pull up on it, forming the peaks you see.
the difference with the squeegee is that there would (or should, at least) be no particularly noticeable amount of ink left behind in the screen after the squeegee passes, thus allowing a clean lift from the print.
thinner ink should help, but then it runs the risk of oozing more and also less opaque coverage.
p.s. this is a well written instructable and a clever take on printing. (and inexpensive, too!)
They have even a better product - StencilPro. You can do a lot more with a product like that than just emulate Print GOCCO.
PhotoEZ is a product that is a pre-emulsion covered screen that you can get and expose to make your own design. PhotoEZ
You combine it all and you get this instructable (which I like by the way, good job).
I think you need to explain this process a bit better -- with more information on the overall assembly of this thing. It took me a few minutes too long to connect the missing dots to see what it is your doing ;)
