Remove these ads by
Signing UpStep 1Parts Used
1. 5 inches of 0.01" 70 degree Nitinol wire
2. A 5 volt power supply .5 amps (this can be replaced with a usb cable)
3. A small wood box from a craft store
4. Two ring lugs
5. Two 3mm counter sink screws and nuts
6. Two plastic wire ties
7. Some 30 AWG hookup wire
8. Super glue
9. A small piece of balsa wood.
10. A 2K resistor and a TIP31 NPN Transistor
11. A 555 timer kit
I have try to reset the initial memory shape without success. For how long do you have to heat up the Nitinol to have it change to the coil shape? I am using a Nitinol Wire .0150" OD, 90C Transition Temp. Does it have to turn red?
it would be great if you could let me know
thanks!
u__u
Good Luck
Phil
Anyhow; without getting yourself in too much trouble - can you run the registry editor? (start+R >> regedit.exe >> run)
If so, navigate to:
HKEY_CURRENT_USER\Control Panel\Desktop
set
ScreenSaverIsSecure = 0
ScreenSaveActive = 0
ScreenSaveTimeOut = 30000 (number of seconds until it kicks in)
Delete key 'SCRNSAVE.EXE' (name of the scr file that runs)
OR ask your IT department to unlock the controls?
